PRIME Z690M-PLUS D4 WiFI
n0ahg
As I needed a MicroATX board with DDR4 to fill the gap until DDR5 becomes available at a resonable price I have a PRIME Z690M-PLUS D4. I need to add WiFi/BT and wondered if anyone knows if I should get a AX211 or AX210. I can't see any mention of CNVi in the manual so I'm leaning towards an AX210.
Any advice would be greatfully received
Thanks
Ray
Shark007
When I looked up your motherboard specs I see
onboard WiFi = M.2 slot only (Key E, CNVi & PCIe) (chip sold separately)
So that would need the AX211 chip.
Of course you'll also need a mounting bracket with antenna's and WiFi wires to attach to the chip once it is installed.
n0ahg
I wish this was mentioned in the manual!
Thank you for the response, I have found the text you mentioned and corrected my typo! lol
