Portable gaming build, PSU and "overheating" advice.
VrVic
hello again everyone,
I'm thinking about building a Micro ATX system for my son who is in college, I want it to :
a- Run the latest games
b- be Portable
c- be upgradable
The concern I have is:
a- The system running too hot
b- Do I have the right PSU for the case I selected?.
c- Are there any other cooling solutions for a Micro ATX build other than Fans?
Here is the list of parts I've selected so far:
Corsair CX750 Builder Series ATX 80 PLUS Bronze Certified Power Supply
Thermaltake MicroATX Cube Cases CA-1D5-00S1WN-00
ASUS Micro ATX DDR3 2600 LGA 1150 Motherboards Z97M-PLUS
Intel Core i5-4690K Processor 3.5 GHz LGA 1150 BX80646I54690K
EVGA GeForce GTX 960 4GB Super SC ACX 2.0+ with Back Plate GDDR5 128bit, PCI-E 3.0, DVI-I, 3 x DP, HDMI, SLI, HDCP, G-SYNC Ready Graphics Cards 04G-P4-3966-KR
Corsair Vengeance Pro Series 16GB (2 x 8GB) DDR3 DRAM 2400MHz C11 Memory Kit (CMY16GX3M2A2400C11A)
thank you in advance for your time and advice.- Victor
Korth
Level 14
Is that one or two GTX960 GPU cards? A 600W PSU would be enough for one card. 750W might be enough for two cards, but 850W-900W would be better.
I actually think the ROG GTX960 Strix would be a better choice than that EVGA GTX960. If you plan to overclock the GPU, anyhow. Or just buy whichever of the two costs less.
That Thermaltake Core V21 Cube chassis is pretty nifty. Modular, reconfigurable, designed to accommodate all sorts of cooling options. It looks like it only comes with one 200mm (front intake) fan, another 120mm-140mm (rear exhaust) fan should be added to expel the heat generated by the GPU card and to increase general through-chassis airflow.
This is one instance where I'd recommend an AIO cooler - like one of these. The fan/radiator could be top-mounted to assist with general airflow, while a large air cooler would actually impede airflow a little too much in such a small case. This case also has a big window, and your son's friends will likely be more impressed by liquid cooling bling than by a large air cooling radiator. BeQuiet! offers a nice collection of CPU air coolers which perform well and look as good as air coolers can get. The Cooler Master V8 is also robust enough for your build and has a decisive impact on overall appearance. Large air coolers can be quite massive, it's a bit unwise to dangle them off the CPU socket in a vertical-motherboard machine which might frequently get hauled off to local LAN parties and such.
I assume a college student's computer will see endless hours of use, including much gaming. And I assume that sooner or later your son will succumb to the temptation of overclocking his rig, lol. It might be worth spending just a little bit more on PSU and cooling to help ensure the whole machine doesn't fail catastrophically under a little strain.
[/Korth]
Nate152
Hello VrVic
In a high end build it would be good to at least go with a gold rated psu. If you want your son to be able to play the latest games at good frame rates a gtx 960 isn't going to cut it. Batman Arkham knight is a new game and is calling for a gtx 980 as the recommended gpu. You could go with that or the NEW gtx 980ti. The 980ti has pretty much the same performance as the gtx titan x which is a 1,000.00 dollar gpu. Game requirements will increase as time goes on. You could get the 980ti for you and give him your 980 lol.
http://www.bhphotovideo.com/c/product/1117257-REG/bitfenix_bfc_phe_300_kkxkk_rp_phenom_mini_itx_chas...
Here is the Asus gtx 980ti, I see the mobo you chose only supports one gpu so you might as well get him the best you can get since you can't go SLI. This is the reference 980ti and heat will get exhausted out of the case with this kind of cooler. Which in a mini/micro itx case would be a good idea.
http://www.amazon.com/Asus-GTX980TI-6GD5-ASUS-Graphics-Card/dp/B00YJG58EO/ref=sr_1_3?s=pc&ie=UTF8&qi...
Compact 750w gold rated psu
http://www.amazon.com/Cooler-Master-V750-Compact-CrossFire/dp/B00ISCG6MI/ref=sr_1_1?s=electronics&ie...
The h100i will fit in the bitfenix phenom at the top.
