point of diminishing return
Heini
Level 11
I started this build with two objectives... AMD/ASUS hardware and get 50 fps minimum in Hitman absolution. Both objectives are met. From the list below what could I replace that would add to the system without passing the point of diminishing return. Maube a 2560 monitor?
Crosshair V Formula-Z
FX-9590
AMD Gamer 4x8GB @ 2133
SAMSUNG 840 Pro 256GB
R9290X-DC2OC (2Xfired)
ASUS VG278HE
Xonar Essence STX
Logitech Z906
ASUS BW-12B1ST/BLK/G/AS
Cooler Master V1000
Cooler Master HAF XB EVO
Razer BlackWidow Ultimate
Razer DeathAdder
4 REPLIES 4
Zka17
Level 16
Well, your system seems to be pretty top notch... the parts themselves are good, maybe you want to try OC'ing for higher fps?
Zka17 wrote:
....maybe you want to try OC'ing for higher fps?
I'm not an OC'r or even a tweeker. I went from 8350 to 9590 cause I'm too lazy to do it myself, lol. I have a reference R9 290 in the closet so I guess if I want to push it I could put it in the PCIe x8 slot and the board would be FULL.
Chino
Level 15
Nate152
2560 x 1440 or 2560 x 1600? I game on the HP LP3065 (30") which is about 6 years old but it does 2560 x 1600 at 60Hz. If you are gaming at 1080p, 2560 x 1600 is pretty much twice as crisp, clear and detailed than 1080p. Or you could do as Chino suggests, I never gamed on a surround monitor set up but It looks pretty awesome from some of the posts I've seen. Your 290x's would eat three 1080p monitors alive.
Some newer monitors do 2560 x 1440 at 120 hz. Three of those would be a jaw dropper.
