PN51 Ryzen 5 - Will two monitors 1440p at 144Hz work?
excel95
I'm considering this setup:
  • Asus MiniPC PN51 Ryzen 5 (PN51-BB555MDE1)
  • Two monitors, Acer VG272UP, 2560x1440, 144 Hz (DisplayPort)
  • One older monitor 1920x1200 (DVI/DisplayPort)
Will the PN51 be able to drive these two monitors 1440p at 144Hz?
How do I connect 2 monitors using a single DisplayPort (don't think "Daisy chaining" is supported by these monitors)? Do I need some adapter? If so, any suggestions of a good adapter?
The "older" monitor, I guess the best way to connect that would be a DVI to HDMI adapter (?)
Any suggestions/feedback is highly appriciated.
Thanks in advance!
xeromist
Theoretically yes, but it depends on the adapter. If you used an HDMI adapter you'd probably be limited to 1440p@120Hz. With a good USB-C DP adapter I think you should be able to reach your target display mode. No suggestions since I haven't tried any myself.
That said, this is a CPU with integrated graphics. Hopefully you're not getting this for gaming or heavy graphics workloads? You can set the display mode but don't expect to play many (if any) games at that frame rate. The new Ryzen CPUs can certainly game but think more along the lines of 1080p and low graphics quality settings.
