plz help me..
Anuj_Gohil
i want to assmble new pc.plz give me advice for my selective hardware.
Hardware:
processor - AMD FX 8350 AM3+
RAM - AMD Radeon™ R9 2400–8GB (2x4GB) DDR3 2400 MHz CL11 Memory Kit
Motherboard - ASUS CROSSHAIR V FORMULA Z
Graphic card - ASUS AMD R7-260x
Hard disk - Seagate SSHD 2-TB
Cabinet - Cooler master Strom TROOPER(4 fan include)
PSu - cooler master V850
Blu ray drive - ASUS blu ray drive
i dont want to use liquid cooling kit.is it safe?
can my pc run perfectly after use this componants?
11 REPLIES 11
aliÃ_nlÃ_
yes certainly! I2m using that one Cooler Master SEIDON 240M and my CPU fx9370 🙂
Tokens210
If that sshd is a hybrid drive I personally never used one but seen nothing but bad stuff written online about them
Besides that you got a decent build going here
Also to answer your water cooling question
You weren't clear in custom or closed loop although I'd assume closed
Is it safe?
Custom loop totally depends on u and how you set it up and test it to whether its safe or not
Closed loop usually pretty safe, as long as u buy it retail and install directly as instructed companies like corsair will actually repay you for everything damaged if it were to break and leak, one guy on overclockers forum got a brand new $1200 build cause he had a defective unit that leaked
Closed loops are ment to be matinance free and built to not be taken apart so they shouldn't really leak
Closed loops that can be expanded you'd need to watch cause they shouldn't leak either they should be just as a plain closed loop but being it was ment to be able to be expanded or taken apart means you'd wanna check the joints and fill port to ensure there snugged up and not going to leak
CoolerMaster HAF 932 Advanced/ Maximus VI Formula/ I7-4770K/Swiftech H320/ Corsair HX850/ G.Skill Trident X (2x8) 16gb 2400MHz/ 2x 840 EVO 120gb(Raid 0)/ WD 1TB HDD (Backup/Storage)/ EVGA GTX 1gb 560 TI/ Asus 12x bluray combo
how much watt is taken for run this system?which psu is best in under 150$?
Anuj_Gohil
liquid cooling kit is strongly required for this processor?
aliÃ_nlÃ_
İ find only this under 150$
CENTAURO SERİSİ 80PLUS 1000W
i will order most of parts online. and how much watt will requird for this system?
but how much watt will requird?
Anuj_Gohil
my budget is 1500$.
