PLED pin issue
Hordin
Hello
i have just bought a new rog x570-f motherboard , the PLED has 2 pins on the motherboard but my chassis connector is 3 pin socket , if i fit it , then the power button only has one pin , the system does boot like this, but every now and then it fails to boot ...... its not stable. The case is a lian li armorsuit , id rather not change it, any ideas please?
AS185
Is the cases HDLED at least 2 pin? You need the power button & reset button attached. You might just have to go without PLED.
