Please help with RGB hub for Asus build on X870-E-E Strix motherboard
BJBBJB
I cannot obtain an answer for this.  I am building my second all Asus build on this motherboard.  With only 3 fans per RGB gen 2 Header I am short 1 fan for RGB control. I have enough headers for fan power.
My question is simple. For the last build I had an RGB only hub left over from a 3 pack of asus fans which worked great. I don't need another 3 pack as I am using reversible asus fans and they don't have the hub. All I can find is the TUF gaming hub which is for many fans and has power support top.
Is this my only option?
What do others do when they are building in a case that has 3 AIO fans, 3 on side, and 3 o  bottom and 1 in back? That is 10.....and 3 RGB headers times 3 fans leaves one left.
Thanks!
BJB
0 REPLIES 0
