01-06-2021 06:09 AM - last edited on 03-05-2024 07:10 PM by ROGBot
01-06-2021 07:57 AM
Silver Fox wrote:
I’m building a new high end gaming desktop PC for my son, using the following components chosen using Part-picker:
Case: Fractal Design Define 7XL Light
CPU: Intel Core i7-10700K 3.8 GHz 8 Core Processor
CPU Cooler: Cooler Master ML360R RGB 66.7 CFM Liquid Cooler
Motherboard: ASUS ROG Strix Z490-E Gaming ATX LGA1200
Memory: G.Skill Ripjaws V Series 32GB (2x16 GB) DDR4-3200 CL16
Storage SSD Windows ‘C’ Drive: Western Digital Blue 500 GB 2.5" SSD
Storage SSD Games Drive: Samsung 860 Evo 2 TB 2.5" SSD
Storage HDD: Western Digital Black 6 TB 7200 RPM
Video Card: EVGA GeForce RTX 3080 Ultra Gaming 10GB GDDR6X PCI Express
Power Supply: Corsair RM 750W 80+ Gold Certified Fully Modular ATX Power Supply.
Optical Drive: Asus BW-16D1HT BluRay
Operating System: Widows 10 Home (on USB Flash Drive)
There seems to be compatibility issues between the following components:
Case: Fractal Design Define 7 XL
MOB: ASUS Strix Z470E
Liquid Cooler: Cooler Master ML 360 R
I have built several desktop PC’s before without any dramas. However, I’m having problems with this build.
I’m very confused as to how to connect the 3 x Chassis Fans, 3 x Cooler Fans and Cooler Pump.
The MOB fan connector sockets are all 4 pin. Yet the 3x case fan connectors are 3 pin female, as are the connectors for the Cooler Fans & Pump.
The Fractal case incorporates a Nexus + 2 Fan Hub with 6 x 3 pin fan connections, 3 x 4 pin PWM fan connections, a SATA power connector and a CPU_Fan / SYS_Fan Connector.
Should I connect the case fans, cooler fans and cooler pump to the Nexus + 2 Fan Hub and ignore the MOB fan connector sockets (which I can’t use anyway as they all appear to be 4 pin PWM)?
Any help in clarifying these issues would be greatly appreciated. It would appear that Part-picker hasn’t matched the Fractal case, ASUS MOB and Cooler Master liquid cooler very well.
01-06-2021 08:16 AM
KMagic wrote:
Off the top, you can connect 3 wire fans to a 4pin PWM fan port on the motherboard - you simply ignore the right most pin on the connector. If you look closely at these plugs and at the little plastic support piece you will notice it sits a little off center for this very reason. The fan itself only needs 2 wires to actually be powered, that is wires 1 and 2 in the pin, and that is 12v power and ground. The 3rd wire is the tachometer wire - it is the wire that reports fan RPM to the motherboard or whatever device it is connected to. The 4th wire is the PWM control, which allows you to control the speed of PWM fans. So really the difference you are seeing here is that all the fans that are 3 pins are simply not PWM fans, meaning you cant control the fans RPM with PWM control. You can still control some 3 pin fans, but it doesnt use PWM, it changes speed by regulating the voltage on the 12v rail feed to the fan. This is how fan RPM was controlled before PWM came along. The downside to using voltage to control fans is that if the fans are RGB fans, the lights in the fan will also dim as the fan slows down, because the voltage is being reduced. PWM allows a fan to run at full 12v all the time, and control the fan RPM by a seperate circuit. This allows you to run fans super low speed if desired and mantain super bright LED's. I say all this to hopefully give you some idea at whats going on here and what youre working with.
You can set this up either way you want to honestly. You can use fan hubs, or you can use the mobo. Either will work. I would base my decision on how I plan to control the fans. Do you plan to adjust the RPM of the fans and tune them with custom curves? If so then take the option that best allows you to do this. Does your pump have a wire coming out of it that is a 3 pin plug but just a single wire connected to it? Some pumps have this, and this is a 3 pin fan connector with just the tachometer wire connected. You would want to connect this to the "PUMP" fan header on the motherboard if you have this. What this does is allow the motherboard to see the pump rpm of your water cooler (But it does not power it - it merely is able to monitor it) This is more a safety feature so that if your pump dies, the motherboard will know it and you will likely hear some alarms or see some error codes to alert you of its failure. The important think to know here though is that you CAN power 3 pin fans on a 4 pin PWM motherboard header. They are designed to recieve either.
01-06-2021 11:09 AM
Silver Fox wrote:
Thanks for the prompt response. Please bear with me as I'm new to this forum.
Your reply clarifies my concerns about the fans. The Fractal case fans I'm not bothered about. However, the 3 fans in the Cooler Master ML360R RGB are of more concern, due to the RGB element. I find the user manual that came with this cooler difficult to understand as it does not clearly explain where the fans and pump should be connected.
01-07-2021 04:05 AM
KMagic wrote:
I looked up the water cooler you mention here to see the specifications. It lists the 3 fans on the radiator as 4 pin PWM fans. I was thinking they were 3 pin based on your post. Looking at the cooler on cooler master's website it also seems that the fans are ARGB. The A there means they are Adressable, meaning the RGB can controlled to provide various lighting effects. This would mean your fans each have 2 seperate wires and 2 seperate plugs coming out of them correct? One will be the plug I covered in the previous reply than controls the fan motor, tachometer report, and PWM control (if its 4 pin). The other wire is for the RGB control. So you do have a lot of wiring here. The RGB wire will have to go into some kind of device RGB control device. It appears the cooler master water cooler comes with an RGB hub, but you didnt mention this? Do you have this RGB Hub? if you do, then the ARGB wiring needs to go through it, and then the hub will likely plug into a USB port on the motherboard, and be powered with a SATA power connection from the Powersupply. The USB connection on fan and RGB hubs is so you can interact with it with some software in windows, it is not to power the hub. So you have to get power to the fans - and you can do that either though a fan hub, or through the motherboard. Then you have to connect the RGB to an RGB hub. Honestly the best way to set all this up is to use something like the Corsair Commander Pro. It is a fan and RGB header and will do all of this in a single device. Not sure how well it will play with your RGB fans as its more so designed to work with corsairs RGB fans, but any fan hub will power the fans. You could power the fans with the motherboard headers and use the RGB hub for the RGB, then there should be some software you will have to install for the RGB hub to control the lights. To control the fan speeds or set custom curves you would need to go into the mobo bios or install the software for the motherboard.
01-08-2021 06:10 AM
01-14-2021 06:32 AM
KMagic wrote:
It is a lot of wiring, but this is actually quite simple. Let's walk through it all. So the pump has 2x 3 pin female connections. One is for RGB control, one is for powering the pump motor. Each of the 3 fans have 2x female connections, one is a 4 pin, and one is a 3 pin. The 4pin is the one that will power the fan and allow you to control its speed. the 3 pin is again the RGB control. The 3 pin RGB connectors all look the same, as you show in your pictures. The diagram you shared shows the motherboard powering all the motors - the 3 fans and the pump, all 4 of those connections go to the motherboard. All of the 3 pin RGB connections are going into the RGB hub in your diagram. The diagram looks a little more confusing I guess because it shows the use of 2 splitters for the fans - one on the RGB hub, and one on the motherboard. The splitters in the diagram show you connecting all 3 fans to a single power header on the motherboard - the CPU fan header. The 3 RGB Fan connections go into another splitter and all plug into one of the 2 ports on the RGB hub. They are using splitters because you only have 2 RGB plugs on the hub in the diagram but you need to make 4 connections. One connection is for the pump's RGB, then you only have one other port, so you have to use a splitter to get all the fans connected. The same thing is occurring with the splitter on the motherboard in order to put all the fans on the CPU fan header. You could forgo that however and use 3 sperate fan headers on the motherboard if you wanted to.
For clarification on which connection is what - the fan and pump POWER connections all have the little plastic ribs on the underside of the plug which slot over the plastic support piece on the connection. The RGB connections do not have these little ribs. The hub itself will live inside the case, along with all the wires. Nothing comes outside of the case for this. Typically these hubs are hidden behind the motherboard tray, or down near the power supply area. You can get creative on how to hide it all depending what case you have.
01-14-2021 09:05 AM
Silver Fox wrote:
Thank you again for your time and for your detailed response.
I am still digesting feedback just received from Fractal , regarding the Nexus-2 fan hub and from Cooler Master regarding their ML 360R.
Their responses were slow due to the Christmas holidays and sickness in their departments.
Please give me a couple of days to make sense of all the feedback I am getting from various sources.
I will post here again soon if I have any further questions or need further clarifications.
Thank you again for you assistance and patience.
01-19-2021 04:11 AM
Silver Fox wrote:
I should explain that owing to my deteriorating eyesight, I've had to 'farm' my partially built PC out to a professional to complete the build.
Since my last post of earlier today and since getting the PC back, Ive had a chance to take a good look at the fan and pump wiring and have made the following observations ( Please refer to the attached Fractal Nexus-2 Hub connection diagram) :
1. Nexus-2 Hub Connections:
1.1 The supplied PWM cable (right hand cable on the hub) has been connected to CHA_FAN1 on the Z490-E motherboard.
1.2 The supplied SATA cable has been connected to the PSU.
1.3 Nothing has been connected to any of the three 4 pin connection points.
1.4 The 3 case fans have been connected to 3 of the 3 pin connection points.
2. Cooler Master ML 360R Fan & Pump Connections:
2.1 All 3 fans have been connected to CPU_FAN on the motherboard, using a 3 way splitter cable
2.2 The pump has been connected to AIO_PUMP on the motherboard.
The connection arrangement described above seems a little strange to me, particularly as there is nothing connected to any of the 4 pin connection points on the Nexus-2 Hub
The Fractal wiring diagram shows the Main CPU 4 pin PWM fan connected to the right hand 4 pin connection point on the Nexus-2 Hub,
but these fans are connected to CPU_FAN on the motherboard, as described in 2.1 above.
I would appreciate your opinion on how these fans have been connected.
It would appear that with the wiring method used, the hub will not receive any PWM signals from the motherboard?
