PLEASE HELP! Need to verify my build.
LewdGeek
Here is what I have and I want to know if everything works fine and I need someone or some people to help me verify everything because I don't trust ASUS at all and I am thinking that the Motherboard is broken or something because if I read this https://www.asus.com/support/FAQ/1043948#6 A0 means something is wrong. and since the beginning I have problem over problem, I've always used MSI hardware and never had a single problem and since I am using ASUS this is problem over problem and I even get a virus or something like that I think. SO PLEASE someone help me because a 4000$ PC should not run like ****...
Here are my specs:
Computer Case: Phanteks - ECLIPSE P600S
Motherboard: ASUS ROG MAXIMUS XII HERO (WI-FI)
OS: Windows 10 Professionnel 64-bit
CPU: Intel® Core™ i9-10850K Processor
CPU Cooler: ROG Strix LC 360 RGB White Edition
GPU: EVGA GeForce RTX 2070 SUPER FTW3 ULTRA
RAM: Corsair - VENGEANCE® RGB PRO 64GB (4 x 16GB) DDR4 DRAM 3200MHz C16 Memory Kit White Series™
PSU: Corsair - RM850x White Series™
NVME: Western Digital WD BLACK SN750 NVMe M.2 2280 1TB PCI-Express 3.0 x4 64-layer 3D NAND Internal Solid State Drive (SSD) WDS100T3X0C
and my GPU is on a Riser: Phanteks PH-CBRS_PR22 220mm / 8.66 in Premium GPU Riser Extension Cables https://www.newegg.ca/p/N82E16812987062?Item=9SIADDZAPH3606
And I have a RGB Hub: Phanteks PH-DRGB_SKT Digital RGB LED Starter Kit https://www.newegg.ca/phanteks-ph-drgb-skt-black/p/N82E16811984021?Item=N82E16811984021
Don't know if those can cause problem on Asus MB but I have writed everything I have, except the HDD and SSD
4 REPLIES 4
marhaba
Hey.
I just added your list to PC Partpicker and there doesn't seem to be any issues that will give you any errors (https://pcpartpicker.com/list/TCtrwz).
What is the problem you're having? A0 usually means everything is working fine.
A0 is an error code when everything is normal its 00 not A0
AO code means that the BIOS handed over control to the OS... it is not an error code!
Show me your proof 🙂 cuz EVERYWHERE it says that A0 is an error and when the computer is running normally while in the OS it's 00, SO please inform yourself before saying random stuff on Forum...
