Please help me figure out why my SATA SSD storage drive won't work right
slxslippy
I recently got an Asus ROG G700 PC. It has a 1 TB Nvme SSD. That one is working fine, but I wanted more space so I took the 1 TB SATA SSD out of my old pc. It had been the primary bootable drive on my old PC. I wiped it of data and ended up reformatting it. I did a full format, which I now know you're not supposed to do on an SSD but it was already running when I found that out so I let it finish.
I would like to note that I am installing this SATA SSD just as a backup, the Nvme drive it came with is still there and working properly as my bootable primary drive.
After that I started the PC, and it shows an error on boot screen saying it's 'Repairing Drive'. When it gets to 100% it boots into Win 11. When I open File Explorer and click on the drive it just spins and spins until File Explorer says 'Not responding'. I end up having to hard power off because everything stops working right including shutdown.
I booted into BIOS and it showed the drive on there too. Here's the problem, I feel like I'm missing a step. All I did was delete the stuff on the drive and reformat it. I didn't do any partitions or renaming. It's still called 'D:' as it was on the old PC. So, is there a step in this process that I am missing or is the drive faulty? The drive worked fine up until I took it from my old PC. I also tried plugging the SATA cable into different ports.
When I was done experimenting with all of this I unplugged the problematic SATA SSD and the PC boots and runs fine without it, so it is definitely the issue.
I don't know if I am supposed to do something beyond the format, whether it's partitioning or something I'm not aware of. Without knowing what I'm missing it's hard to Google for answers.
Any help would be appreciated. I don't want to buy a new SATA SSD because if the problem isn't the drive itself then I'll have the same problem with it.
Update: I can access the drive with an powered adapter cable from within Windows. So I initialized it again and reformatted. However, it was still showing the partitions from when it was my main bootable drive in the old PC (Windows Healthy Recovery, etc). So I learned how to delete those with diskpart in powershell. Got that done, initialized it again and quick formatted it. Then I powered the pc off and put the SATA SSD back in and connected the SATA cable and the power. Rebooted and it did the 'Repairing Drive' thing again, for even longer this time. PC booted up finally after about half an hour and was running really slow. Disk manager just spun and wouldn't load again. Had to hard shut down. Tried booting to BIOS to see if there was something there I was missing, and the SSD didn't even show up in the list of drives in boot order. I saw it in there another time I tried it a few days ago.
I disconnected it from the PC and when I reboot the PC boots and runs fine.
I don't understand why the drive is readable with the usb adapter cable but not when properly connected within the PC. I guess something may have been messed up on it from being a bootable drive and then reformatting, etc. a couple times. I'm reluctant to buy a new SSD because if that's not the problem then I wasted the time and money. If its something wrong with the PC I need to figure that out before the 30 day return window.
Update 2: I discovered CrystalDiskInfo and downloaded it. Hooked up the SATA SSD with the usb adapter and tested it. It's showing as 'Good 93%' health. So I guess the drive isn't the problem?
(I posted this on Reddit earlier but literally nobody replied so I looked for somewhere else I could ask. Copied it here, that's why it has updates and stuff.)
0 REPLIES 0
