Please help ! Building a GAMING Pc !
alerace15
Budget: $2500
Main uses of intended build: Gamign PC
Parts required:Motherboard,Processor,GPU,Chassis,RAM,HDD,SSD,PSU,Fan Controller,CPU Cooler
Monitor resolution: 1080p
Storage requirements:SSD=120GB HDD=2TB
Will i Overclock: Yes
motherboard requirements : SLI or Crossfire Suitable
Extra information about desired system:
Black and Red Theme
Sleek Look
Silent
Awesome Performace
Awesome Cable Management
Full tower case or mid tower can suit SLI or Crossfire .
THANK YOU IN ADVANCE
9 REPLIES 9
Antronman
Level 11
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($324.98 @ SuperBiiz)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($99.99 @ NCIX US)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($219.99 @ Amazon)
Memory: G.Skill Trident X Series 16GB (4 x 4GB) DDR3-2400 Memory ($184.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($79.00 @ B&H)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($81.97 @ OutletPC)
Video Card: Asus Radeon R9 290 4GB DirectCU II Video Card (2-Way CrossFire) ($379.99 @ Newegg)
Case: Corsair 760T Black ATX Full Tower Case ($159.99 @ Micro Center)
Power Supply: EVGA 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($149.99 @ Newegg)
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer ($57.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Case Fan: Corsair CO-9050012-WW 37.9 CFM 120mm Fan ($27.95 @ Amazon)
Fan Controller: NZXT Sentry Mix 2 Fan Controller ($34.99 @ Newegg)
Total: $2271.78
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-02 11:59 EDT-0400)
As quiet as it's going to get.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
but what can i subsitute if i want a nvidia card thanks i would really appreciate if you can reply 🙂
Footman
I agree with Antroman on motherboard and memory choice, however if you have some time, I would hold off for Devils Canyon CPU's. The Evo is a great SSD, I would go for a larger capacity, the 480gb. Also if you are gaming at 1080p, I see no real value in CF or SLI. Get a factory overclocked GTX 780Ti and spend the money saved on the larger SSD and 4790K CPU.
Just IMO of course.
alerace15
Thank you for the tips guys 🙂 !
Antronman
Level 11
hmmm. I guess GTX 780s?
2 asus 780 will do for 4k resolution or triple monitor about 23'' ? can it be ?
Antronman
Level 11
Triple Monitor, maybe.
No to 4k. You'd need to raise the budget to 3000USD to get good 4k fps.
alerace15
ohhh thank you what about the best IPS monitor for about 29-30'' ?
abvolt
Level 11
great list for the op antronman can't go wrong there..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
