PG49WCD cycles through colors when woken up randomly
nvarade
Hello,
This does not happen all the time, but when I wake up my computer from sleep, the monitor will start cycling through red, green, blue and white. It goes on for a while, unless I change input or press the X button that is next to the OSD buttons behind the monitor.
Is this normal behavior? or is there a setting I need to tweak or change?
Thanks for any help!
0 REPLIES 0
