PCI Simple Communications Controller ?
Flourgrader
Hi Guys,
I have just installed windows 11 (21H2) build 22000,778
on my ROG GL553VE Laptop.
I have a yellow triangle over PCI Simple Communications Controller
in the Device Manager section.
Can someone point me to the correct address where I can download this
Driver please ?
Thank You 🙂
ahfoo
Flourgrader wrote:
Hi Guys,
Driver please ?
Thank You 🙂
Bro, you need to install Intel ME driver for this.
Please refer to this thread created by MoKiChU,
https://rog.asus.com/forum/showthread.php?117609-DRIVERS-Intel-Chipset-MEI-SATA-VMD-(1xx-2xx-3xx-4xx...
Flourgrader
Thank you, ahfoo
The link you gave me was most helpful.
I think it would be A good idea to include this on the
support page for the driver downloads?
Silent_Scone
Super Moderator
Hello,
Please be sure to check on root (c:\esupport) for any support files or documentation*
