PC won't start unless I power cycle my PSU
Bhammer
My pc works fine until 1 day it just won't start. For 2 weeks i need to turn my psu off then on and press the case button immediately for it to power on. When it turns on it functions normally. Does someone know a fix for this? I have already checked all the connections, changed the socket and power brick. Tried the Pin method with the PSU jumpstarter that comes with it and the psu turns on fine. Tried removing the GPU, Reseating CPU and RAM, CMOS, changing the Cmos Battery, Removing the PSU extension cables.
The thing is when i try to turn on my PSU my mouse lights up. If i do not press the power button immediately and let the Mouse RGB lights up for 2 or 3 seconds it won't turn on. Tried turning the PC on without any Peripherals connected and still won't turn on.
I thought of changing the Motherboard but My pc works fine if it turns on. no chrashes, no freezing, no BOD, It can stay on and I can use it as long as I want if it is on. The only Problem is i need to cycle the PSU off then on first.
Does anyone have the same issue and did you fix it? Could it be a PSU failing?
PC Specs:
CPU: Ryzen 5 7600x
Motherboard: Asus ROG Strix B650E-E Gaming Wifi
RAM: Gskillz DDR5
GPU: Asus ROG Strix 6900xt LC
PSU: Seasonic Focus GX 1000W
PC Build is 2 yrs old
I have seen the same post here but it is locked.
Does someone know a Solution to this?
0 REPLIES 0
