Pc rgb case lights not turning on (g10dk prebuilt)
Idiot224
it used to work and out of no where it just stopped working. i have tried everything at this point and have made NO changes inside the computer.
brittany9086
I am having the same issue. Mine went to other colors I did not set and then went out completely. It is driving me nuts. Good luck hopefully we can get a solution.
