Other Devices: Unknown
Primal_49591
After installing all the drivers, I'm left with 6 Unknown Devices in the Device Manager.
Windows update does not find. Installed the AMD drivers.
Board is a Prime X670E Wi-Fi.
ACPI\AMDI0052\2&DABA3FF&0 (AMD, but why don't the chipset drivers detect?)
4 REPLIES 4
inge70
Level 14
You can't rely on Windows Update.
This usually doesn't work with current hardware.
Download the latest drivers (chipset, NPU, etc.) from the Asus support site and install them.
You should also write down the exact name of the motherboard; I couldn't find a "Prime X670E Wi-Fi," but I did find a "Prime X670E Pro Wi-Fi."
Intel Core i7 13700K / AiO Fractal Design Lumen S36 v2 RGB / Asus Rog Strix Z790-F Gaming WIFI / Corsair Dominator Platinum DDR5-5600 64GB (4x 16GB) / Asus TUF RTX 5070 Ti OC / 4x Samsung 980 pro 1TB / Seasonic Prime GX 850 W Gold / Fractal Design Meshify 2 Lite RGB Black TG Light Tint / Monitor AOC Q27G2S/EU (WQHD)
Yes, it's the "Prime X670E Pro Wi-Fi". I've downloaded all the drivers and installed.
The "DRV_Chipset_AMD_NPU_SZ-TSD_W11_64_V320203242_20250225R", first comes up with this window and disappears after 3 secs, nothing happens. Also directed Windows to the folder in manually install and install as admin.
The driver package in the Asus site isn't complete. The AMD 3D V cache optimizer is missing
Download from AMD.
https://www.amd.com/de/support/downloads/drivers.html/chipsets/am5/x670e.html
I'm also facing a similar issue, and actually I am looking for some kind of software that will detect and install missing or newer versions of drivers for ASUS motherboards.
