They swapped it reluctantly , definitely the fan they cleaned it and fired it up in the shop.
After about 15 mins of running flat out, you could see a very faint line of oil down one of the fans and some tiny spots around the edge.
However they had no 92mm fans or a NH-U9B in stock so I went for a NH-C14 instead only £4 more?
Now I have just got to make it fit.
ittle OG
Maximus VI Impact - I7 4770k - GTX 780 DC2OC
Trident X 2400 2x8Gb - Samsung 840 500Gb - CM120 Elite
Corsair Ax860i - H90 2x CF-V14HP
