New triple Titan X system on Rampage V Extreme --> Intel 750 PCIE?
FrodBonzi
Hey everyone,
First time on this forum - though I do have the original Rampage in my current system (hence the need for an upgrade - the q9450 is getting old).
I'm building an "uber" system with 3 Titan X GPUs and was wondering about the PCI lane limitations of adding an Intel 750 SSD...
I know that it is recommended that it go into a 4x PCI 3 slot - if I have 3 Titans (assuming x16,x8,x8), will there actually be physical room for the Intel 750?
I saw the "coming soon" connector for the m2 version - but that's a few hundred extra dollars and I don't think I should need it...
Any thoughts?
14 REPLIES 14
Praz
Hello
The Titans need to go in the first three PCIe 3.0 x16 slots and the 750 in the last PCIe 3.0 x16 slot. The M.2 adpater for the 2.5" drive is less than $30.00 (U.S.)
FrodBonzi
ohhh... less than $30 sounds good... I'll wait for that... just realized that the 3.1 card probably takes that last PCI slot anyways... so m2 is probably the way to go...
Chino
Level 15
Due to the placement of the M.2 socket on the R5E, using the ASUS Hyper Kit might obstruct the GPU in the first PCIe lane.
Korth
Level 14
Another option would be to use a PCIe SSD card instead of an M.2+PCIe. These are typically a striped RAID array of 2-4 discrete SSD controllers and NVRAM modules (plus some amount of DRAM cache) embedded onto a single card, all seen by the operating system as a single indivisible drive/controller.
The ROG RAIDR, Plextor M6e, and G.Skill Phoenix Blade all offer impressive Read/Write/Access (similar to SATA SSDs in striped RAID configurations). Some models are available with prices, capacities, and performances comparable to (or much better than) the Intel 750. And they don't occupy any PCIe 3.0 lanes or utilize a dedicated M.2 slot (which means they also don't lock out any other slots, ports, or other hardware resources on the motherboard). You could conceivably populate a motherboard with many such cards and move them from machine to machine with little difficulty.
These cards have been used in enterprise-class machinery for a while, and are now a "mature" storage technology which offers greater speed, reliability, longevity, and flexibility than consumer M.2 storage. I honestly don't know why M.2 is being pushed hard into the mainstream while PCIe SSDs are still seen as an oddball "niche" item (but I suspect most consumers think M.2 is the best new thing out there because they see every new motherboard proudly advertising M.2 compatibility).
Incidentally, a striped RAID of 2 or more good old SATA SSDs will offer similar (superior to most M.2) performance and price, in my opinion. It's hard to beat the price and performance of a striped pair of Samsung 850PRO SSDs, doubly so when their performance is multiplied through their RAM-caching software.
[/Korth]
Hello
There are few PCIe 2.0 drives that will match the performance of the 750. The couple that will are very expensive and as you note are enterprise drives that reach their performance at high queue depth. Few users will use their system in a way that will require these queue numbers.
Korth
Level 14
You may be right. It doesn't hurt to look at the shocking numbers on the benchmarks, lol. The Intel 750 M.2 is fairly respectable, but I feel there's a lot of better options.
Regardless, if available space/geometry is constrained then you may still need to defer the M.2 solution. I don't think any 12GB Titan X cards are going to come out in small (<9") form factors, lol.
[Edit]
Far be it for me to criticize Asus (especially on their own forums, lol), and to be honest, I have been entirely pleased with my excellent RVE mobo (so far). But it seems to me that since M.2 is still an evolving nonstandard addon, and since using it typically imposes tradeoffs on other (finite) mobo hardware resources/space, it would make sense to physically position the M.2 in such a way that populating it with a full-sized module interferes only with the particular slots/ports it happens to lock out. Just sayin'
[/Korth]
FrodBonzi
OK... question.... is there a difference in performance between the 750 PCI and the 750 in m2?
Menthol
Level 14
Theoretically no, I don't know anyone with the 2.5 inch drive though, there will always be trade offs especially running multiple GPU's, you have to give up something, in your case either the Intel 750 or the USB 3.1 daughter card. The Samsung SM951 is a very fast M.2 drive and in the coming months we will see new drives being released
So if there is no difference... I'll just get the 2.5" and put it in M.2... will still have 4 PCI lanes for the USB 3.1 card...
Can still run my 3 Titans at 16x8x8x.... Is there a reason that won't work?
