04-24-2025 12:51 PM
My build
Asus rog strix x870e-e
CPU AMD 9800x3d
Ram G. Skill trident Z5 neo rgb DDR5-6000 16gbX4 CL30
Asus ROG Astral 5080oc
is this what the voltage should be for the cpu? I keep getting Q-code 32
04-24-2025 06:19 PM - edited 04-24-2025 07:48 PM
Hello Thechosenwiller
Code 32 is most likely your cpu temperature, does the code fluctuate?
In the bios, Advanced tab, Onboard Devices Configuration, if the Q-Code is set to Auto, it will show your cpu temperature.
If you set it to Post Code only, it will show normal codes.
Set to Post Code Only, when booted into windows, it should show code AA.
