New PC need advice on Asus Motherboard and Graphic Card
eternaly
Hey guys,
I'm building a new pc with these parts
Motherboard: ASUS Z97-DELUXE ATX DDR3 2600 LGA 1150
Graphic Card: ASUS Graphics Cards MATRIX-GTX780TI-P-3GD5
CPU: Intel Core i7-4790K Processor
Case: Cooler Master Cosmos II
Power Supply: EVGA SuperNOVA 1300G2
Memory: Corsair Vengeance Pro Series 16GB (2 x 8GB) DDR3 2666MHz
CPU Cooler: Corsair Hydro Series H105 Extreme Performance Liquid CPU Cooler
with samsung ssd
I'm not really sure what kind Motherboard and graphic card to get as there are sooooo many different choice (and I'm a noooob on pc building).
So here's the Question
1) As PC gammer (Like to have all setting on High and hv 60+ FPS) which Asus Motherboard should I get? ( don't know how to OC but will learn how, and I do understand some Asus Motherboard come with Easy OC? which is made sample and safe to do)? correct me if im wrong >_>
2) Graphic Card I do see that there are many choice of GTX 780 TI out there (now I had my eyes on EVGA GTX 780 TI classified k ngp n edition) however my friend just strongly suggest I get Asus Graphic Card ( >_>). So....Which Graphic Card should I get?
I won't buy all these parts until mid October so will there be new stuff on market? (I do see there are DDR4 2011 but they seems too expensive atm my budget is 2500-3000
Thanks for your time~
8 REPLIES 8
Chino
Level 15
Welcome to the ROG forums, eternaly.
At what resolution will you be playing at? And do you plan on adding more monitors down the road?
Here's tha Post I have on pcpartpicker on what kind pc im looking for it's alittle long...
https://pcpartpicker.com/forums/topic/47329-high-end-pc-build-budget-2500-3000-please-take-a-lookty
ty, and it's 1920x1080 Acer HN274H;)
randyenergy
If I was in your shoes I would take:
- ROG motherboard: http://www.asus.com/Motherboards/MAXIMUS_VII_FORMULAWATCH_DOGS/
- Swiftech H220-X CPU Liquid Cooling Kit: http://www.swiftech.com/H220-X.aspx#tab1
- Corsair Dominator (Forget about Corsair Vengeance): http://www.corsair.com/en/dominator-platinum-with-corsair-link-connector-1-65v-16-gb-dual-channel-dd...
- Asus Swift PG278Q monitor: http://rog.asus.com/349542014/gaming-monitors/video-definitive-overview-of-the-swift-pg278q/
DDR4 doesn't work with this line or any previous line. For DDR4 you have to get new motherboard and new cpu. But don't dispair.
If you say you won't buy all these parts until mid October, then you are lucky, because the new Intel line (X99) is going to be release at the end of August, albeit more expensive.
If you prefer to take the Z97 route, watch this video: http://rog.asus.com/341582014/labels/guides/video-how-to-build-a-gaming-pc-using-rog-z97-hardware/
he did not list DDR4 memory.
And for Memory will only buy 16gb for now , can always add 16g more later if need.
not recommended since you will only ask for problems if doing so.
always get 1 ( one ) kit of the amount of memory you want.
ram speed go for 2133 - 2400mhz to be sure you can get it all stable.
abow 1866/2133mhz you will not notice enny diffrence from day to day use
even take a look at the g-skill ram and see if they can be enny cheaper, the majority of the OC'ers on this forum uses it.
GPU go for a 780TI.
and chino is going to give you a good setup if i know him right.
Read again.
Arne_Saknussemm
Level 40
Definitely get one kit of whatever size you need...don't mix kits. The Vengeance pro is OK but maybe you can find faster CAS kits there is some G.Skill 2600 cas10 about...
The Maximus Vii Formula is hard to beat and at 1920x1080 I'd say an ASUS GTX780 DCuII. The matrix is a bit overkill unless you are LN2 OCing though a very nice card of course... The DCuII even has a bit more OC margin by all accounts and is cheaper...
Antronman
Type|Item|Price
**CPU** | [Intel Core i7-4790K 4.0GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i74790k) | $338.99 @ NCIX US
**CPU Cooler** | [Corsair H105 73.0 CFM Liquid CPU Cooler](http://pcpartpicker.com/part/corsair-cpu-cooler-cw9060016ww) | $99.99 @ Newegg
**Motherboard** | [Asus MAXIMUS VII FORMULA ATX LGA1150 Motherboard](http://pcpartpicker.com/part/asus-motherboard-maximusviiformula) | $299.99 @ NCIX US
**Memory** | [G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2666 Memory](http://pcpartpicker.com/part/gskill-memory-f32666c11d16gtxd) | $229.99 @ Newegg
**Storage** | [OCZ RevoDrive 350 Series 240GB PCI-E Solid State Drive](http://pcpartpicker.com/part/ocz-internal-hard-drive-rvd350fhpx28240g) | $500.98 @ Newegg
**Storage** | [Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003) | $52.91 @ OutletPC
**Video Card** | [EVGA GeForce GTX 780 Ti 3GB Dual Classified ACX Video Card](http://pcpartpicker.com/part/evga-video-card-03gp42888kr) (2-Way SLI) | $659.00 @ Newegg
**Case** | [Corsair 760T Black ATX Full Tower Case](http://pcpartpicker.com/part/corsair-case-760tblack) | $129.99 @ Micro Center
**Power Supply** | [SeaSonic Platinum 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply](http://pcpartpicker.com/part/seasonic-power-supply-platinum1000) | $179.99 @ Newegg
**Optical Drive** | [Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer](http://pcpartpicker.com/part/asus-optical-drive-bw12b1stblkgas) | $49.99 @ Newegg
**Operating System** | [Microsoft Windows 7 Professional SP1 (OEM) (64-bit)](http://pcpartpicker.com/part/microsoft-os-fqc04649) | $139.99 @ NCIX US
**Case Fan** | [Noctua NF-F12 industrialPPC-2000 PWM 71.7 CFM 120mm Fan](http://pcpartpicker.com/part/noctua-case-fan-nff12industrialppc2000pwm) | $29.95 @ Amazon
**Fan Controller** | [NZXT Sentry Mix 2 Fan Controller](http://pcpartpicker.com/part/nzxt-fan-controller-senmix2) | $25.78 @ Amazon
| | **Total**
| Prices include shipping, taxes, and discounts when available | $3426.49
| Generated by PCPartPicker 2014-08-24 12:57 EDT-0400 |
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
