New PC build - Looking for advice on parts.
Omyth
Hello everyone! As title says im looking to build a new PC and hand my current one over to the wife.
Budget is around 2000$
Intended use: Gaming mostly.
What im looking for:
Looking to put in a nice clean gaming motherboard because of the case design. I would prefer one that lights up nicely. I would also need RAM, SSD's, Power Supply, amazing fans, and a CPU water cooler wich I was thinking the Swiftech H220 X (I will likely not watercool this tower but I might in the future.) So the fans would need to be good for the temps and low noise.
I am looking to overclock the CPU as well.
Case I pre-ordered: EVGA DG-87
GPU I was thinking the 1070? I think the 1080 is a bit too pricey.
Monitor resolution: Currently using 1920x1080 but would consider upgrading for a good price.
Thanks for your time! Any questions please ask.
13 REPLIES 13
MeanMachine
Hi Omyth and Welcome to ROG 😄
Here is an example of a good Gaming rig that would meet your budget.
Go to the site and modify to your hearts content.
Prices are in US dollars and does not include your choice of monitors or case as I could not find a listing for EVGA DG-87
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($494.00 @ CPL Online)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard
Memory: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory ($134.00 @ IJK)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($189.00 @ PLE Computers)
Video Card: EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card
Case: Corsair 780T ATX Full Tower Case ($259.00 @ CPL Online)
Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($264.00 @ IJK)
Operating System: Microsoft Windows 10 Pro OEM 64-bit
Other: Braided cables (Purchased)
Other: 6 pin and 24 pin braided
Total: $1340.00
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-06-17 13:59 AEST+1000
Have fun with your build 😉
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
Nate152
Hello omyth
Welcome to the ROG forum !
Since you budget is $2,000.00, let's do a z170 build.
I would like to see you upgrade your monitor to at least 1440p, the GTX 1070 would do well at that resolution and likely overclock well but we'll see where we're at then you can decide on a monitor.
Motherboard with RGB lighting - Maximus VIII Hero Alpha or Maximus VIII formula, the formula costs more but you have the option to liquid cool the vrm's as your cooler is expandable.
Hero 8 Alpha - $229.99 with rebate card http://www.newegg.com/Product/Product.aspx?Item=N82E16813132699
Formula 8 - $399.99 http://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP3RS8211&cm_re=maximus_viii_formula-_-13-132-2...
PSU 1000w - $129.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16817438010&cm_re=evga_supernova_1000-_-17-438-0...
Swiftech H220X2 prestige - $189.95 http://www.swiftech.com/h220x2prestige.aspx
Ram - $109.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16820232205&cm_re=TridentZ-_-20-232-205-_-Produc...
1TB SSD - $306.76 http://www.newegg.com/Product/Product.aspx?Item=N82E16820147374&cm_re=samsung_1tb-_-20-147-374-_-Pro...
Fans RGB - 53.99 https://www.amazon.com/Thermaltake-Riing-120mm-Adjustable-Radiator/dp/B014QW98SC?ie=UTF8&*Version*=1...
GTX 1070 - $449.99 https://www.amazon.com/Gigabyte-GeForce-Founders-Graphics-GV-N1070D5-8GD-B/dp/B01GKD93IU/ref=sr_1_3?...
i7-6700k - $314.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16819117559&cm_re=6700k-_-19-117-559-_-Product
Total with the Hero 8 Alpha - $1785.65
Total with the formula 8 - $1955.65
Taxes and shipping may apply. You'll need fittings for the vrm's on the formula (if you go with it) and to expand your cooler(compatible fittings).
3/8 x 5/8 tubing is a good size and you will need a bottle or two of coolant. Will you need an operating system?
Nate152 wrote:
Hello omyth
+1... I would go maybe on Hero non ALPHA, and look to save every dollar for investing in cheapest GTX1080.
I think cheapest GTX1080 cost arround 600-610$. 20$ on PSU (850W instead 1000), 30-40$ on motherboard(Hero instead ALPHA), 2 case fans for 25$(corsair Twin Pack) instead of 50$ and little buy little you crawl closer GTX1080.
Except that this configuration is best... who will pay 2000$ for Z97 and 4x4GB RAM and 260$ for PC Case and 4790K... .
Hmm.. So I do agree with Vlad in lowering some parts.
Im thinking of doing this:
Hero 8 Alpha: 230$
i7 6700k: 315$
Swiftech H240 X: 150$
16Gb Ram: 110$
6 Noctua fans: Not entirely sure on what ones yet, but say 240$
1TB SSD: 310$
1080 GPU: Price?
Thats a total of 1355$ not including the GPU. I get so confused with the 50 types of the same card from 15 different makers that I have no idea wich one is best bang for your buck so to speak.
I have also taken into consideration the warning of the swiftech and still I think im gonna go with it. Ive done a lot of watching vids and reading forums and they all point to it being the one I want. But thanks for the heads up.
I need at least 6 fans because im going to replace the stock fans and there is 2 on both sides plus the 2 on the rad. Quiet is best for me, but I do not want to sacrifice performance by lowering the fans rpms just for it.
I can also take 1 of the 250Gig SSDs from this current PC, and buy a smaller say 500Gig SSD for storage instead. That would also lower my price down a bit I feel. In fact scratch that, I will just take all my SSDs from this PC, and put them in the new one so that saves me 310$ and just swap her current drive into this tower. lol
Menthol
Level 14
I would also recommend a Z170 build, Nate's build is excellent
I have to give my opinion on the Swiftech cooler, although they seem to get very good reviews and look very nice, come with some of the best fans, I purchased a 240X from Newegg that came with a leak, fortunately it was leaking in the box so I never installed it, which could have been very bad, they didn't have any more in stock so I returned for a full refund, I then purchased one from Performance PCS with the same outcome, it was also leaking in the box, I also returned for a full refund, which took much longer from PCS as the refund had to be approved by Swiftech, I probably will not try Swiftech again
Thanks for the suggestions!
For MeanMachine:
You suggest buying braided cables and braided pin? Where would I buy those? I would love if I could have everything neat and tidy.
Nate:
I love the build parts, and yes I need an OS because im handing this PC to my wife so I will need one for the new PC as well. I do not particularly like that H220x2 look, not as sleek as the H220x, is there a big difference in performance between them?
I like the Formula 8 look way more so I will go with that for sure.
If I do get the h220 should I add the vrms to the loop? I was not planning on doing that to begin with.
With the resolution issue, would I need a new monitor? and if so, any suggestions?
Menthol:
I will keep that in mind and hope for the best. I am in no rush 🙂
For MeanMachine:
You can purchase braided cables from a number of companies EVGA for example supply kits to suit your PSU.
Google around for best prices and suppliers.
BTW: NATE has suggested a better build than what I showed as an example. I merely wanted you to be aware of PartPicker.
My System Specs:
CPU:
[/HR]
kkn
Level 14
just as an sugestion, have OS on one ssd and games on the other.
and do not overfill the ssd's.
Heini
Level 11
I've tried several aio coolers including the Swiftech H240 X and the best of the bunch is easily the EK Predator. With them you need no software, they are controlled from the MB bios.
edit to add...... They have quick-connects for adding gpu's to the loop.
