Hello, I'm hoping that someone in here might be able to give me some guidance. I just built out a new PC and I'm having a strange problem. Sometimes the PC won't post. If I press MemOK on the mobo, it will post right up. When it's running, it runs fine without any noticeable issues or lag.
When I first bought the components, I accidentally purchased a 7th series CPU and had issues trying to get it to start up because of that. Once I got the 8th series installed it came up no problem. Then I discovered that one of my RAM sticks was dead. The warranty covered that and it was replaced.
I haven't tried too many things because I honestly don't know where to start. I've checked each stick of ram by itself, but one of the problems seems to be that once it posts, it will be fine for a little while. But if I leave it sitting overnight off, it won't post up again the next day. This makes troubleshooting a little difficult as I sometimes won't have immediate feedback on if my changes did anything. I have also tried securing all of the connections to all of the components and moving the video card into a new slot.
I did seem to have some brief success when I disabled fastboot in the BIOS, but the problem came back again pretty quickly.
Another problem that I face that may or may not be related is that the computer will not wake up from sleep. I have followed the online recommendations for turning off certain Windows 10 features, but none of that seems to have worked.
I am a little scared about modifying voltages on the motherboard as that would be my first time doing anything like that, but I really need this computer to work properly as I spent a LOT of money on it. Any advice would be GREATLY appreciated. Thank you so much for reading.
Build Specifications with links to their Newegg or NVIDIA pages:
TowerThermaltake View 71 RGB 4-Sided Tempered Glass Vertical GPU Modular E-ATX Gaming Full Tower Computer...MotherboardASUS ROG Maximus X Hero (Wi-Fi AC) LGA 1151 (300 Series) Intel Z370 HDMI SATA 6Gb/s USB 3.1 ATX Inte...RAM (x2)G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory M...ProcessorIntel Core i7-8700K Coffee Lake 6-Core 3.7 GHz (4.7 GHz Turbo) LGA 1151 (300 Series) 95W BX80684I787...CPU CoolerThermaltake Floe AIO Riing RGB 360 TT Premium Edition PWM TR4 LGA2066 Ready Liquid Cooling System CL...Power SupplyEVGA SuperNOVA 750 G2 Power Supply - ATX12V/EPS12V - 110 V AC, 220 V AC Input Voltage - 3.3 V DC, 5 ...SSDsSAMSUNG 860 EVO Series 2.5" 500GB SATA III V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-76E5...Graphics CardNVIDIA Titan XP
