11-01-2015 11:31 PM - last edited on 03-06-2024 01:37 AM by ROGBot
11-03-2015 04:20 AM
11-03-2015 08:38 AM
11-05-2015 12:03 AM
11-05-2015 06:39 AM
RuslanM wrote:
Hi Everyone,
A quick question regarding the 5820k and PCIE slots/performance.
I just read the manual on the motherboard that PCIE_X8_4 (SLOT 6) will be disabled if using 28 cpu, that was my slot for intel pcie ssd 😞
The 1st slot is gonna be taken by GPU, so that leaves us with slot 2 and 4.
If I install the SSD won't the GPU get x8 ? I might be wrong
11-05-2015 06:52 AM
Chino wrote:
Assuming you can even use the PCIE_X16_1 slot at all. As stated earlier, the NH-D15 extends over the first PCIe slot because of its huge size. But if you manage to fit your GPU in the PCIE_X16_1 slot, then install your Intel 750 into the PCIE_X16/X8_3 slot.
11-05-2015 07:11 AM
Hardliner wrote:
And that is 'if' you get the 40-laned 5930K CPU and not the 28-laned 5820K CPU (16 + 16 = 32 lanes).
11-05-2015 07:25 AM
Chino wrote:
The 5820K will be ok. With the GPU is installed in the PCIE_x16_1 slot and the Intel 750 in the PCIE_X16/X8_3 slot, the GPU will be running at X16 as long as he doesn't add anything else to the mix.
11-05-2015 10:59 AM
11-05-2015 12:37 PM
RuslanM wrote:
After debating with you guys and myself for quite a while, I changed it to 5930k 🙂
