New Build Won't Post
Finnigan
Hey! Finally got my new computer put together today. Getting some Q code errors. The first was C5. Then I updated the BIOS using a USB drive and the BIOS flash button on the back. Appeared to work as the small led flashed for a good many minutes then stopped. C5 went away and now showing a 15. I can't figure this one out. Something to do with RAM? For this I tried putting only 1 stick in every single ram slot - still no post. I then did the same with the second stick. I also tried two in A2 B2 then A1 B1. Still that 15 with nothing on the monitor. I tried plugging the monitor into the motherboard and GPU. Any ideas?
AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor
Asus ROG STRIX X670E-E GAMING WIFI ATX AM5 Motherboard
TEAMGROUP T-Force Delta RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory
Crucial T705 W/Heatsink 2 TB M.2-2280 PCIe 5.0 X4 NVME Solid State Drive
MSI GAMING X TRIO GeForce RTX 2080 Video Card
Corsair HX1000i 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply
Silent_Scone
Super Moderator
Hi @Finnigan
Please be sure to wait at least 3 to 5 minutes initially for the system to train memory. The code will be 15.
