New Build with Asus Front Base +5 fans
GGHOOST
Hi ROG owners
I am soon going to build my first watercooled PC 😄 (First time ROG parts :D)
To cool the rads, and case i am going to use the included 2x 120 fans and 1x 140 fan. Beside that i am going to cool the 2 rads with 6 corsair SP120 PMW highperformance fans (1 with push/pull and 1 pull). I have read that the Frontbase has 5 fan cables.
My question is, does anyone know how much power each cable can handle? :confused:
I want to use y-splitter cables.
I want to connect 4 corsair fans to 1 cable, 2 corsair fans to 1 and 3 included fans to 3 cables.
I hope someone can help as i am new to all this. 😛
4 REPLIES 4
kkn
Level 14
im not 100% shure but take a max on 1Amp on each channel.
so as long as the amount of fans together dont go over 1 amp on each fan header i guess you will be safe 🙂
what mobo and sutch are you getting?
Thanks for the info. Each of the fans are 0.18 A so it should be under 1 A 😄 If not i will connect 2 fan per channel 😉
Right now i have only bought half the part, and i am still looking for a good place to buy the watercooling gear here in Europe.
But It will include:
Asus Maximus Formula VII
Corsair Vengeance Pro 16GB in Red
Asus GeForce GTX 780 Poseidon
Fractal Design Newton 1000 Watt in White.
CM Storm Stryker
Intel i7 4790K
Asus Front Base
Corsair SP120 PMW
Asus VG248QE 24" Monitor
Corsair Vengeance M65 Mouse
Asus Slim External DVD Drive.
Corsair Vengeance K70 Keyboard
Samsung Pro 256 GB SSD
kkn
Level 14
where in europe?
you have aquacomputer.de ( germany based and stock their own parts )
aquatuning.de <- they ship all over the world whit main storrage in germany and they do not stock EK parts enny more.
GGHOOST
I have looked af overclockers.co.uk they have all the parts i want, and specialtech.co.uk.
Specialtech have all the parts, but it is not possible to make a order unless the part is in stock, and i can't see the pictures for the parts... 😞
I have looked at the website you suggested, but they do not have the parts i am looking for, but Thanks 😉
