New Build using MAXIMUS V GENE
sandeep3010
Motherboard:
ASUS MAXIUMUS V GENE
GPU:
ASUS GTX 670 DirectCU II TOP
Model No: GTX670-DC2T-2GD5
Processor:
Intel i5 3570k
RAM:
Requirement : 8gb 1600
Please advice.
I checked out the memory support list provided for V GENE by ASUS.
A few queries related to that:
1. Only the specified models for the various brands will work at the designated speed ?
2. Which of the following variation is better :
a) single 8gb stick
b) 2*4gb KIT
c) 2*4gb separate packing
In India the following RAM models are available for purchase. But these are NOT mentioned on the MEM Support PDF provided by ASUS for MAXIMUS V GENE.
Please brief me which one of these will work at the specified speed without any issues
____________________________________________________________________________________________________________________________________
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Model: CMZ8GX3M2A1600C9
Corsair Vengeance DDR3 4 GB (1 x 4 GB) PC RAM (CMZ4GX3M1A1600C9)
Corsair Vengeance DDR3 8 GB PC RAM (CMZ8GX3M1A1600C10)
G.Skill RipjawsX 4 GB RAM (F3-12800CL9S-4GBXL)
G.Skill Sniper 4 GB RAM (F3-12800CL9S-4GBSR)
G.Skill Ripjaws 4 GB RAM (F3-12800CL9S-4GBRL)
G.Skill RipjawsX 4 GB RAM (F3-12800CL9D-4GBXL)
G.Skill Sniper 8 GB RAM (F3-12800CL9D-8GBSR)
G.Skill RipjawsX 8 GB RAM (F3-12800CL9D-8GBXL)
Power Supply:
Corsair CMPSU – 700GS
Cabinet:
Cooler Master HAF 912 Advanced Mid Tower Cabinet
Hard-Disk:
Seagate Barracuda 2 TB HDD Internal Hard Drive (ST200DM001) 6gb/s 64mb cache 7200rpm
Monitor:
Benq 24 inch LED - RL2450H
DVDRW:
Asus DRW-24B3ST
SSD:
I will purchase one in December, Not NOW
COOLING:
I am new to OC.Never done it before
So as per now I am not planning to invest in the liquid cooling or dedicated cooling fan components for GPU & CPU.
I will do that later after a deep understanding in domain of OC.
PLEASE ADVICE AS SOON AS POSSIBLE
4 REPLIES 4
HiVizMan
Level 40
Ram
Dual channel (two sticks) is more beneficent than a single stick.
Get a kit of 8GB go for the ripjawx 8GB kit.
HiVizMan wrote:
Ram
Please specify a model from the above mentioned options in Indian market
http://www.flipkart.com/g-skill-ripjawsx-ddr3-8-gb-2-x-4-gb-pc-ram-f3-12800cl9d-8gbxl/p/itmd2rysqgrm...
