New build problems
ronaldmackool
Can anyone tell me if my ram is compatible with my new Asus ROG Strix B550-F motherboard.  When  I searched Crucial the following memory popped up . 4 sticks of 16 GB Crucial DDR4-3200 UDIMM. I keep gettim DRAM error lights {Yellow. Thank you.
Silent_Scone
Super Moderator
Hi @ronaldmackool
It may help if you posted the memory kit part number. Also you can find the Memory QVL on the support site, here
You will get DRAM Q-LED lit whilst memory training takes place. This initial process can take anywhere of 5 to 15 minutes or more depending on the DRAM configuration.
Thanks for your help. Unfortunately I let it go for approximately 20 minutes and still not working. Again, thanks for your help.
Hi, are you able to answer my question above
