02-20-2012
03:03 PM
- last edited on
03-06-2024
09:43 PM
by
ROGBot
02-20-2012 03:13 PM
02-20-2012 04:26 PM
grottslampan wrote:
No, its not overkill.. If you want to run an extra high-end gpu later, you will need it.. And keeping OC on all..
Its better to be some + on the psu, the Voltage is not always stable, when pushing less powerful psu's, with heavy gear..
I Love that I5, Its sooo much power for the penny........ And overclock easy..
I dont know why, but people recommend and buy (at least i think so), to weak psu's for their equipment.. Sure it works. BUT
Once i find a good working psu, i keep it, and use it for many years.. Its worth the xtra 40 usd in the long run..
And hell YES...... Parts on the way!!!!!!!!!! SCREW Santa........ I know that FEELING........:cool:
02-20-2012 03:42 PM
02-20-2012 04:32 PM
trailer park boy wrote:
i always go big on the psu,why build a monster truck and put a lawnmower engine in it
02-20-2012 03:48 PM
02-20-2012 04:30 PM
HiVizMan wrote:
Those samsungs are the sweetest things you will own. They make the whole combination you have put together top in my book. Run your RAID for OS and applications. Use the other mechanical drive for the bulk storage. There are a couple of really good guides here on ROG. Go have a look in the article section.
Very sweet set up.
02-20-2012 04:45 PM
02-20-2012 07:32 PM
02-20-2012 09:39 PM
