12-05-2020
07:09 PM
- last edited on
03-05-2024
07:29 PM
by
ROGBot
12-05-2020 08:42 PM
12-05-2020 08:47 PM
12-06-2020 10:12 AM
12-06-2020 10:30 AM
12-06-2020 10:35 AM
12-06-2020 02:41 PM
MoKiChU wrote:
If it helps you, at the top right of each ASUS motherboard, there is a label with the serial number of the board and the buit-in BIOS version (the last 4 digits being your BIOS version), if the version is equal to or greater than 2606, the motherboard is Ryzen 5xxx compatible, if the version is lower, the motherboard is not Ryzen 5xxx compatible out of the box and the BIOS must be updated.
12-06-2020 08:34 PM
12-07-2020 04:01 AM
Braegnok wrote:
USB BIOS Flashback, no CPU or memory needed,..
https://rog.asus.com/technology/republic-of-gamers-motherboard-innovations/usb-bios-flashback/
12-07-2020 04:26 AM
Krigeren wrote:
I'm building a new PC and I am running into an issue I can't solve. If anybody can offer some help or advice, it would be greatly appreciated.
My components:
Asus Rog Strix X570-i Gaming
AMD Ryzen 9 5900x
16gb x 2 G.Skill Trident Z Neo 3600mhz cl16
RTX 3070
When I try to boot, I get no signal on my monitor, and the POST state LED is yellow, indicating a DRAM issue.
I've tried
- Reseating both ram sticks
- Only using 1 ram stick (tested both sticks individually, in both slots)
- Reseating CPU
- Connecting to monitor with both display port cable and hdmi cable
- Using a different graphics card
- Checking PSU connections
- Clearing CMOS (via jumper short circuit)
RGB on motherboard, ram, gpu is all lighting up. All fans are running fine.
When I ordered the motherboard, it specifically said it would support zen3, but I am unable to check which bios version I have, and to my understanding I can't update bios without having a functional cpu and actually booting up, which I can't. Would an unsupported cpu produce a yellow DRAM error?
Is a DRAM issue enough to not even get a video signal? I would expect to atleast get some more helpful error messages, but all I have is the yellow led indicator.
Does anybody have any idea what could be the cause of this issue, or suggestions to how I can proceed in figuring this out?
Best regards,
John
