12-01-2018 03:28 AM
12-01-2018 03:41 AM
12-01-2018 11:18 AM
Silent Scone@ASUS wrote:
Do you mean the Formula XI? I've been using the board since launch with no problems at all. 5GHz on all cores with 4GHz memory on a full custom loop with temperatures controlled on Q-FAN via Water in T header.
All of this can be done via the UEFI within Q-FAN including the fan curves and min and max duty. There is no need to install software if you desire not to use Ai Suite.
Regarding fan configuration, I would personally remove the need for a fan controller from the system and make use of the onboard fan controls. Depending on the fans used, using a single header can split the tach signal over the 4 fans (make sure to use the right splitter with single tach signal). Standard headers provide 12W, with the high amp header providing 36W. Alternatively, PWM hubs are also fine, sending a single tach signal to the respective header.
12-01-2018 04:18 AM
12-01-2018 06:46 AM
Ashwind wrote:
I have had a formula VIII and now a formula IX and to be perfectly honest the water cooling header / features are a bit of a gimmick or at least a half-arsed attempt at water cooling features.
For example you have a dedicated water pump header that you can only set a pwm curve for from the CPU temps not the coolant temp, the water in/out you cant use for pwn curves either, the only way I could get use any pwm curve with coolant temps was to plug my temp sensor into temp sensor1 header which granted does work but why have all these water cooling features that 'almost' work
12-01-2018 11:35 AM
12-01-2018 04:47 AM
12-01-2018 11:48 AM
JustinThyme wrote:
Straight up no BS.
12-01-2018 03:00 PM
Guttermedic wrote:
Thank you Justin, That's what I was afraid of and was in the back of my mind. Mobo's in the past have never been as smart as their marketing teams protrade them to be.
I think I will look into a different mobo to buy and leave the cooling to external controllers. After finding out that Asus flat out lied about the VRM and the whole phase BS, and now the pump, flow, fan headers are not as cool and neat as it sounded.
Time to put that mobo money into performance not LCS
12-02-2018 02:45 AM
Keep in mind that it helps to have the board you're complaining about, which some users do not. Making blanket statements regarding onboard fan controls, and then not really elaberating on why something is fubar doesn't help anyone.
I've been a power user a lot longer than I have been affiliated with ASUS, and can honestly say there are no issues with running Q-Fan on the board. My x299 system uses an Aquereo 6, and when it comes to simply setting up Q-FAN on the Formula XI there's no real disadvantage. If anything (in that regard), it's better - as there's no service required in the OS. It's also possible to setup fan control based on a number of sources, not just CPU temperature.
All depends what you are looking to do, but if you’re buying an external controller simply to control two or three signals then personally, I feel it’s a waste of money (if one knows how to set things up correctly).
