New Build Boot Issues with ASUS Pro WS W790-ACE - Q-CODE and DRAM Light Color Troubleshooting
VapDash
Hey all. I've been unable to successfully boot my new build. My friends are just as bewildered. So, I'm reaching out to this brilliant community for some help. Thank you all in advance for any insights or suggestions you might have!
I'm using an ASUS Pro WS W790-ACE motherboard. Before I tried all of this, I successfully upgraded the BIOS via BIOS FlashBack utility, and right after that, I cleared the CMOS. I only have one stick of RAM. I tried a few different things to troubleshoot but can't interpret the results:
What I attemptedQCODEDRAM Light Color
DIMM_A1 (recommended)29Yellow
DIMM_A217Yellow
DIMM_F167Yellow
No RAM stick60Yellow
Attaching my build here:
ComponentProduct
MotherboardASUS Pro WS W790-ACE
Graphics CardMSI Ventus GeForce RTX 3060 12GB
RAMCrucial 64GB Server Workstation Memory - DDR5 4800MHz
PSUbe quiet! Dark Power PRO 13 - 1600w
CPUIntel Xeon W5-2455X
SSD (M.2)ADATA PREMIUM SSD FOR PS5 M.2 2280 2TB
CaseFractal Design Define 7 XL
AIOEnermax LIQTECH II TR4 360
TPMASUS TPM-SPI
FansNoctua NF-A14 FLX, 3-PIN 140mm
Ahituna
Hi!
have you been able to solve this? Stuck with the same problem…
VapDash
After testing all the RAM slots, I managed to boot up the system using one of the slots farthest to the right. In an effort to identify the issue, I tested another RAM stick from the QVL, differing in both size and manufacturer, but encountered the same problem, thus eliminating the possibility of a faulty RAM stick. Using the working RAM slot, I successfully installed Windows 10 and observed unusually high CPU temperatures even at idle. I decided to disassemble everything, and rather than using the plastic CPU casing provided with the motherboard, I used the one that came with the CPU.  Upon reassembly and restarting, everything was running smoothly. My diagnosis is that the CPU was not properly seated initially. I had noticed that my CPU did not quite fit into the housing provided by ASUS which I believe to be the root cause.
