Needs Suggestions for Liquid Cooling
Mehwish
I have a question that which liquid cooling i can use for OC system? I am living in Saudia so here custom cooling kits not available and not professional technician for making custom liquid cooling system. Therefore i will go for like Cooler master, corsair or nzxt. I need advise that which liquid cooling i will go for it and which model will be best for OC?
Regards,
Intel i7 5930k
Asus X99-Deluxe
Corsair Dominator Platinum 16gb DDR4 3000MHZ
Samsung Pro 512mb
AMD Radeon HD 7990 (Custom Cooling Loop for GPU)
Corsair Hydro series 100i
Cooler Master HAF XM Case
12 REPLIES 12
EnthusiastBuild
Level 12
Hey Mehwish
I am pretty satisfied with my Corsair H100i and I do recommend it! You can see my system specifications in the signature.
Cheers!
CORSAIR 900D
ASUS MAXIMUS VI FORMULA
INTEL I7 4770K @ 4.5 GHZ
CORSAIR DOMINATOR PLATINUM 16GB @ 2400MHZ
SLI EVGA GTX 780 SC ACX
SSD SYSTEM: CORSAIR FORCE GT 120GB
SSD APPS: CORSAIR FORCE GT 240 GB
HDD STORAGE: WD BLACK 2TB
CORSAIR AX860I PSU
CORSAIR H100I 4 x SP120 HP
Thx for your kind reply. My specification you can see below and recommend me bcz in my pc case i think only 1 liquid cooling can adjust.
Processor: Intel i7 3930k
MOB: Rampage iv Extreme
SD: Corsair 120 force gt
Memory: Kingston hyper x beast 32 GB 2400 mhz
Graphics: AMD Radeon 7990 HD
Power Supply: Corsair 1200w
Fan: Antic not remember exactly (1 cooling fan only)
Case : Cooler Master HAF XM
Intel i7 5930k
Asus X99-Deluxe
Samsung Pro 512mb
kkn
Level 14
are you thinking of closed loop cooling or custom cooling??
closed loop you have the corsair h100i and h110i ( last is dual 140mm fan slot ).
and you have the cracken series and other.
if custom then you have a real expensive cooling solution.
i am thinking of closed loop cooling bcz in my country there are no any professional tehncican to know about custom cooling kit, so please give me suggestions then i will go for modest OC.
Intel i7 5930k
Asus X99-Deluxe
Samsung Pro 512mb
kkn
Level 14
for you i would guess dual fan slot rad is the best ( 240 ( 120 × 2 ) ).
menny have gone for corsairs h100i and there are other ones too.
you can go for that one or if you have the space and mabye the monney then look at the h110i.
take a look around and see what price range they are on.
custom cooling you can buy online and import if so.
its easy realy but you do take a chance on expensive equipment if there would be leakage and sutch.
Mehwish
so corsair h100i is good right? i have read too many reviews and forums and i want to ask about how cooler master eisberg 240l prestige will be compare to corsair h100i?
Intel i7 5930k
Asus X99-Deluxe
Samsung Pro 512mb
Yes h100i is good and all tests i seen h100i led the pack plus 5 year warranty
The seidon pump is louder and some don't like the way the pump is mounted to the motherboard
Here is Pauls Hardware test link for aio and tells about loudness of pumps
Astek most all pumps,they have the patent,Coolit is pump manufacturer for corsairs kits
http://youtu.be/DhkWrSmvrZk
Hardocp review of h100i and h80i pretty intensive testing
http://www.hardocp.com/article/2013/02/12/corsair_hydro_series_h80i_h100i_cpu_cooler_review/#.Uq
ch_f...
H100i test,review and benchmarks
http://youtu.be/b-QMUmybZig
kkn
Level 14
that i do not know. sorry.
EnthusiastBuild
Level 12
Im happy and satisfied with the H100i for my needs, as i stated above. I think you can't go wrong with it. Buy it and replace the 2 already installed fans with 2 Corsair SP120 High Performance and aswell i recommend buying 4 in total of them and do a push / pull config.
Cheers
CORSAIR 900D
CORSAIR AX860I PSU
