needs some help
adicc
so should i wait for maximus vii formula or go with the Maximus VI Extreme
7 REPLIES 7
MeanMachine
Hi adicc
Both are excellent MBs imo, Personally I would wait for a few of our ROG overclockers to review the latest releases,If you can wait that is!!
Check this out: http://www.overclock.net/t/1493490/ds-asus-maximus-vii-impact-and-maximus-vii-formula-z97-launched
Very sexy.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
skywalker311
It all really depends on what you are going to be using it for. The M6E has a OC panel and is a great OC board and if you are going to be running more then 3 graphic cards then this is the mobo that you need to get. Now for the MVIIF (new mobo) it a great all around mobo. Run this with a new devil canyon i7-K CPU and I wouldn't be surprise if you it OC to 4.8 to 5GHz. It also has the onboard audio that is just as good ad a sound card. Great for running SLI or a single graphic card.
New data ports, has a copper water block , Both run dual channel 32 GB of DDR3 memory. In my opinion, the best motherboard that going to be on the market soon. Back to the extreme mobo. It a killer oc board. Save you a little $ and go with M7F it be $300 to $320 same for the CPU. Look around and you probably can get the new i7 for $300 to $310 if you have a mirco center you can get it for $230. Only 1 and you have to buy it in store. Hope this help a little.
Phanteks enthoo primo, i7-4770k, ASUS MVIF, 16GB G.Skill Trident X Ram, ASUS 780 Ti DC2O, Samsung 120GB and crucial M500 480gb SSD, 1TB Western Digital Hard Drive, NZXT 850W power supply
EK Supremacy, EK ASUS MVIF Water Block, EK Monarch Series X4 Ram, EK ASUS 780 Ti DCII, EK 420 Cool Stream Rad, XPSC 240mm RAD,Monsoon Series Two Dual Bay Reservoir, Swiftech MCP655-PWM-Water Pump, Monsoon Compression Fittings & Tubbing, Mayhems Pastel Red with Mayhems ultra pure h20.
adicc
yea im getting the devil canyon for sure so i well just wait on that mobo
adicc
this is what i have picked out so far but i dont have any ram picked out yet or a hdd or ssd how ever i set that up not sure yet. and im going a caselabs m8
kkn
Level 14
the 7 series will not have the extreeme in their lineup this year. ( witch was posted some where on this forum. )
adicc
have another look what i said
kkn
Level 14
wait for the formula.
