Need help with GPU Coolers.
stigping
Hi. I recently got to buy all the stuff for my build but gpu cooler and i am wondering where and what to get.
I have 2x Zotac GTX 770 4GB
http://www.zotac.com/products/graphics-cards/geforce-700-series/gtx-770/product/gtx-770/detail/gefor...
CPU: i7 4770k 4.7Ghz 1.425v
MB: Maximus VI Formula
RAM: G.Skill Ripjaws Z DDR3 1866MHz (4x4) 16GB
GPU1: ZOTAC GeForce GTX 770 4GB
GPU2: ZOTAC GeForce GTX 770 4GB
PSU: XFX ProSeries XXX Edition 850W PSU
SSD: Samsung SSD 840 EVO 120GB
HDD1: Seagate Barracuda 2TB
HDD2: Seagate Barracuda 3TB
Case: CM Storm Trooper Gaming
Mouse: SteelSeries Sensei RAW
KeyBoard: Razer Blackwidow 2013
Monitor: BENQ XL2420T
9 REPLIES 9
kkn
Level 14
do you want to change the coolers on the cards you have ??
or do you want those coolers??
i mean an additional cooler.
isn't that the ones that you can mount on the back?
HiVizMan
Level 40
There is no such cooling as far as I am aware, what folks do do is replace the stock cooler with a water cooler but that is about it.
kkn
Level 14
you can mount a fan on the side door if possible, so it takes cold air from room and blow on to the side of the cards.
its either that or do custom watercooling witch will void warranty and get expensive.
ok, thanks guys 🙂
I will not do anything then.
Antronman
Level 11
I think he means a Watercooling Backplate.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
no, an adittional cooling solution......
I put adhesive copper heatsinks (small) on the back of my vid card on all the chips for an inexpensive supplemental cooling solution
welshy46
you could try one of the directional fans on a bendy stick pointed at the back of each gpu to blow air over the back of the gpu socket but as long as you have a decent air flow through the case the, which most cases do these days. The coolers on the cards should be adequate, unless you want to water cool both cards, which should never be discouraged.
There's this if you want to try to mount two of them. Should be easy enough, provided theres enough space between the cards.
http://www.dabs.com/products/arctic-cooling-accelero-hybrid-video-card-liquid-cooling-system-alumini...
Board: MVIF
CPU: intel core i7 4770k@4.8GHz
GPU: R9 290x
RAM: 16gb Corsair Vengence 2133MHz
SSD: ROG RAIDR 240gb PCI-e SSD
Case: Coolermaster HAF xb
Cooling: custom water loop
Monitor: Asus PB278Q
My build log photo dump
