Need Help With Connecting Fans
Not_Enough_Rage
Level 11
Hey everyone,
I am building a new PC, and I need help please,on which would be the best header to connect the fans to on the mother board. This PC will be water cooled with hard line tubing. I have 2 360mm radiators w/ 3 fans on each rad. The 7th. fan is the exhaust fan mounted at the rear of the case. I also have an EK 011 D Distro plate with a pump on it.
I don`t know which header to connect these fans and the Distro pump to, and what type of hubs or splitters I need. The Lian Li PC case and fans came with hubs, so I don`t know if these are all I need. The fans are ARGB too. I`ll give all my PC specs below. Thanks all.
Lian Li 011 Dynamic XL case
Asus ROG Maximus Z690 Hero Mother board
Intel i9 12900K CPU
EVGA FTW3 Ultra RTX 3090 GPU
EVGA 1200 W P2 Power Supply
Corsair Dominator Platinum 32GB 5600MHz DDR5
2 Samsung 980 Pro 1TB NVMe M.2 SSD`s
EK Quantum Velocity2 CPU Water Block
EK Quantum Vector2 ABP Set GPU Water Block
Bykski 360mm x 60mm Radiator
Bykski 360mm x 40mm Radiator
7 Lian Li BR Digital RGB Fans
Monsoon Water Fittings and Acrylic Hard Tubing
BitsPower Flow Indicator
xeromist
Personally I connect my pump to the wpump header and set it to a fixed RPM. You don't usually need variable pump speed, just enough to keep everything flowing based on your loop's restriction and beyond that higher speeds don't buy you cooler temps. Fan speed matters far more.
Ideally you would use a temperature probe in your loop and use the water temperature to control fans speeds. That way when you get small spikes in activity you don't get fans ramping up and down. Water cooling easily absorbs those small spikes so you really only need the fans to ramp up when under sustained load(and thermal output).
If you're interested Jayztwocents has a recent video on some open source software that can control fans based on more than one input temperature. So if your rad fans are cooling both your CPU and GPU you might want them to ramp up if either of those components gets hot. I haven't tried the software myself but the potential to use multiple sensors is intriguing.
