Need help upgrading a really old PC.
Djask
Please don't ask me to buy a new one.
Specs:
Galaxy 8600gt
Core 2 quad q6600
Gigabyte s series motherboard
2 gb ram
Amaroo 500w psu
Wd 320gb caviar black
My budget is quite tight, $400-$500.
Thanks.
Asus G46VW
i7 3630QM | 750GB Hard Drive | 1080p Full HD Display | Corsair Vengeance 16GB | GTX 660m | Windows 7 Ultimate
7 REPLIES 7
HiVizMan
Level 40
The only thing that will really make any different is a SSD hard drive and I am not even sure it is compatible with that motherboard bios. Best ask on the Gigabyte support forum about that.
Chino
Level 15
HiVizMan
Level 40
Thanks.
Here you go
billyray520
Ha! I thought you were serious about your really old PC. I am in the process of upgrading my old Micronix 386 @ 20 Mhz and 2 MB of Ram. I want more RAM.... I'd like to get 8 MB, and I might have a line on the needful. 😉 I already upgraded the old MFM hdd that was on a RLL controller to two IDE hdds, and added a new 3.5" fdd. It dual boots MS DOS 3.3 and PC-MOS 4.0 :cool:
Asus Maximus V Extreme BIOS 1903, see specs above avatar.
Asus G73 jh A1 laptop, BIOS 213, vBIOS OD2, 8 GB Ram, 240 GB Intel SSD, 180 GB Intel SSD. Win 7 Pro. Purchased new from PowerNotebooks.com in May 2010.
(both have 1920X1080 hd screens, mine above, hers below )
Asus G73 Sw XR1 laptop 8 GB Ram, 160 GB Intel SSD, 80 GB Intel SSD. Purchased used >Ebay 1/10/13, Did clean install of Windows 7
Djask
Ii think i'll just buy a new pc. 😧
Asus G46VW
chrsplmr
Level 18
Djask ..
What are you going to use it for ?
What OS ?
Max. Memory Limit?
PSU ?
Are there more funds available ??
HiVizMan
Level 40
It might be best if you did list the uses that you need your system to manage, and then also list the uses you would like your system to do.
