Need help choosing a motherboard
BlueboyX
Budget: $5000 (total build)
Main uses of intended build: folding@home, gaming with Oculus Rift
Parts required: Motherboard
Previous build information (list details of parts):
PNY XLR8 Enthusiast Edition GeForce GTX 780
PNY XLR8 GTX 580-LC-CPU PhysX
i7 2600k @ 4.2ghz 24/7 Folding@home
Azza Hurrican 2000
ASUS P8Z68-V Pro
G.Skill Ripjaws X 16GB (4 x 4GB) 8-8-8-2
Intel 520 SSD 120 GB
Seagate Barracuda 7200rpm 3TB x3 in RAID 5
WD Blue 500gb
LG 16x Blu Ray burner WH14NS40
ASUS 24x DVD burner DRW-24B1ST
Creative Sound Blaster X-Fi Titanium
Hauppauge Colossus DVR Card
Astro A40 Gaming Headset
Corsair TX750 PSU
Windows 10
NVidia Shield
Logitech G502 Gaming Mouse
Logitech HD Pro Webcam C920
Razer BlackWindow Chroma Gaming Keyboard
Monitor resolution: 1080p while on a monitor, 2160×1200 while on the Oculus Rift
Storage requirements: Will be using the PCIE Intel 750 SSD
Will you be overclocking: yes
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): Prefer 7 PWM fan headers, SLI, wifi, DTS connect
Extra information about desired system:
I have already purchased most of the components for my first water cooled build. It will spend most of it's time crunching numbers with folding@home, possibly some video conferencing for work as well as gaming with the Oculus Rift when the consumer version comes out. I already have a EVGA Supernova 1200w power supply, 6700k CPU, 8gig G.Skill Ripjaws V DDR4, LG Blu-ray burner, Corsair 780T case, Windows 10 and a lot of water cooling stuff. For my current PC I chose a sandy bridge CPU and added parts to it over time. I am considering temporarily moving the GTX 780 to this new build until pascal comes out. I do intend to OC, but one that stable for 24/7 use.
The big question I have is 'which motherboard do I go with?' I have built a bunch of computers for office use and my current gaming computer listed above with asus motherboards, so I want to stick with that. I have never tried a ROG motherboard though and was wondering what that would get me that the asus z170 Deluxe did not have. I do like the idea of having an optical output with DTS connect for my Astro headset. It looks like going with a ROG board will get me access to a bunch of utilities. Hero and Ranger seem pretty similar in price and features. The oddball price-wise is the Extreme, with some rumors of a $500US cost. Other than the OC panel and being physically bigger, what does it have that the Hero and Ranger don't? Since this is a high budget rig my initial impulse was to go with the maximus viii extreme, but the asus marketing does not seem to show much in the way of justification of doubling the price over the Hero or Ranger.
Thank you for your assistance. 🙂
5 REPLIES 5
Chino
Level 15
The Extreme is built for overclocking so you get a beefier VRM and other exclusive overclocking features like the OC Panel, PCIe lane switches, voltage readout points, etc... You also get an extra PCIe 16 slot so a 4-Way CrossFireX configuration is possible. And there's an onboard U.2 port now instead of having to use the ASUS Hyper Kit addon to support U.2 SSDs.
Thank you for your quick reply. Is there any specific info on the OC II Panel itself?
Thanks. 🙂
kkn
Level 14
just asked JJ if the mobo would support this cable -> http://www.newegg.com/Product/Product.aspx?Item=N82E16816118224
like for example run ssd/hdd's in raid 5 for example. ( just quriosity )
