Need help! Asus rog gladius or logitech G700s?
Panhai
hi i am looking for gaming and work mouse.
need some advice. which one shall i get? the asus or logitech.
comfort is priority.
thanks
19 REPLIES 19
Ahtlon
Well, I still use the logitech G9x, perfect for claw, my son has a Corsair m65, bought it because he plays more strategy games as fps, If you have big hands, you can use the m65, my son also use the claw grip for this mousse. The M65 is a nice mousse, but expensive.
If I was you I would go to a pc shop and try some mousse and buy the one that feels right in your hand. You play FPS, so to much buttons at the side is not so good,
I would say 3 buttons at the side is enough for FPS. About mousse without cable, well there were only 2 that I could say that was good for FPS, the old Microsoft X8 sidewinder and the razor, my other son still use the X8 for FPS.
With cable is the only way that you can say that there is almost no delay with the input, but some will still feel a delay with a cable mousse.
Panhai
how about madcatz R.A.T. 9 looks pretty cool 🙂
Nate152
That looks like an interesting mouse. Another feature a mouse has to have (at least for me) is on the fly speed adjust.
Panhai
how about corsair m65?
now it is the mouse pad lol which one shall i get? i am looking at the mm600 2 sided mouse pad from corsair. what do you think guys?
Panhai
tried all the mouse. the ratz mouse not really comfortable and it is expensive. at the end i got a corsair m65 rgb. nice custom colors. lol
Panhai
how about the steelseries DEX mouse pad?
Tefon
got g700s do not get has inheritance issue that its older brother has do sent save profiles properly randomly resets back and forward buttons stop registering untill you reboot even a replug dosent fix itits a bad idea avoid like the plauge
sectionate
Level 12
Best products on the market - www.zowiegear.com
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
Vlada011
I like Gladius mouse, I will read these days what people say about him.
ASUS give two additional Omron switches...Japan Omron?
That's little advantage over other mouse who use Omron China.
I would replace them immediately and send other in garbage.
