Need expert help for deciding
Jakob_Zmrzlikar
Hi!
A friend of mine asked me to help him with this. He has $2000 budget and he needs something good for work (documents, presentations, light video editing) and gaming. I considered the following options:
1. Macbook pro + ps4
Macbook pro is probably one of the best laptops for work. It's thin and light, has brilliant screen, long battery life and excellent keyboard and trackpad. Core i5 and 8 GB of RAM is probably enough for all work and 265GB of ssd is a lot. If it rums out you can still get external hdd. This version of Macbook pro costs $1600.
Ps4 is probably the best budget choice for gaming. It has 8 core cpu, 8 GB RAM, good gpu and 500GB hard drive. DualShock 4 is also very good. Since my friend has a FHD TV (not really fancy one but still), he can play at 1920x1080. The ps4 costs $400.
2. Macbook air + gaming pc
Macbook air doesnt have the screen of Macbook pro, but still has enough power for less demanding tasks. I considered the 4gb RAM 128GB ssd model for $1000.
This leaves $1000 for gaming rig. I came up with the following:
Cpu: intel 4670k ($200)
Mobo: ROG Maximus vi hero ($200)
RAM: 8GB g skill ($100)
Gpu: Rog striker 760 ($300)
Cooler: corsair h100i ($100)
Psu: corsair cs 750 w ($100)
Case: a really cheap one
Hdd: he already has one
3. Only gaming pc
So maybe a $2000 gaming pc would be o.k. for everything he does, even though he said he'd prefer to have something portable. Anyway, this is what i considered:
CPU: Intel Core™ i5 4770K ($300)
RAM: G.Skill 8 Gb ($100)
GPU: 2x ASUS Striker GTX 760 4 GB sli ($600)
MOBO: ASUS MAXIMUS VI Formula ($250)
PSU: CORSAIR RM 850w ($150)
Case: Cooler master Cosmos II ($370)
Cooling: CORSAIR Cooling Hydro Series H100i ($110)
SSD: SAMSUNG 840 PRO series 128GB ($120)
So what do you think? Which one should i tell him to choose? I know that z97 is coming out, he might wait for them. But still, this doestn change the price.
-Jakob
11 REPLIES 11
Antronman
No macs plz. Too overpriced.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
Jakob_Zmrzlikar
Ok, ok, maybe some other laptop then. But what do you think about gr8, g20, gx500, razer blade or desktop pc. Which one should my friend get, or which combo (maybe gr8 + a laptop)? Overall budget is around $2000.
-Jakob
