Need build advice.... from AMD to Intel
MenaceRx
I have had this system for a few years now but I have decided to jump to Intel on the processor side of the house. So I am looking for all the feedback and recommendations anyone wants to give. If you can provide data to support your recommendation from personal experience with a board and chip that will be greatly appreciated. I am leaning toward the i7, but I dont want the extra cost for the i7 if and i5 will do well for me for the next 2 years maybe 3 until DDR4 and the newer lines become more cost effective.
So here is what I am looking at.
i5 4690k vs a i7 4790k for my CPU selection.
Currently looking at the following boards
ASUS Z97-A LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132118&cm_re=z97-_-13-132-118-_-Product
or
ASUS Z97-E LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132287&cm_re=z97-_-13-132-287-_-Product
The rest of the ASUS boards seem nice but more then my needs on the Intel side.
***The only reason I wont look at the Haswell - E selections is the shear cost of all 3 components to redo the central core of the machine (CPU/Board/RAM)***
I am planning to keep the rest of my components which are listed here minus the board cpu swap:
AMD FX 8350 w/ H60 Liquid Cooler
ASUS Crosshair V Formula Z Motherboard
32 GB of G. Skill Rip Jaw @ 1600
7870 GHz Edition (Was a 970... RMA, going with a 300 series now in the spring)
Thermaltake 750W PSU Modular
Rosewill Mid ATX Blackhawk Gaming Case
Lastly and importantly. This is what I use my computer for, besides gaming... I do a lot of video conversions, Photoshop and Illustrator work. And Autodesk 3DS Max visual rendering. Those are the heavy lifting examples of what I use it for.
Example of what I do with it... I painted that car in PS CS3 and rendered it in Autodesk 3DS Max for a video game. I do about 200 cars a year for this game I spend time on and so I use these video and illustration apps extensively.
5 REPLIES 5
Antronman
No 7870GHz edition.
Nope, nope, nope.
You want a K2200 at least. You'd benefit much more from that.
i7 would be the way to go for processor upgrades.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
MenaceRx
Oh I know the 7870 is time to go to pasture, it has served me well, run everything just fine. The 970 had a heart attack on me so I am just going to wait and do the video card after the board and CPU. Like I said in the spring the R9 300's come out. Will re-evaluate then.
Antronman
No, you don't understand.
http://geforce.com/
You don't need those.
http://www.nvidia.com/object/workstation-solutions.html
You need these.
MenaceRx
I get you now sorry I misunderstood you. How do the Quadro's hold up in gaming? Any experience there?
X-ROG
Level 15
CS3 afaik is too old to use significant use of GPU, and it depends what version of Autodesk you use whether it just uses rendering or calculations too.
I'm not sure how you use video memory and if you'd need a double-memory card; whether 290X 8GB cards would benefit for example (or even how AMD versus Nvidia is supported in your software versions).
I think, given your budget, Quaddro is possibly overkill for you.
