01-25-2014 12:05 AM - last edited on 03-05-2024 11:51 PM by ROGBot
01-25-2014 12:47 AM
01-26-2014 04:11 PM
kkn wrote:
for GPU you need a larger PSU, try the 750W.
never skimp out on the PSU and if it takes a huge load it will fry up in the end and CAN damage parts on your pc.
for sli i would say 850w as a minimum , single card 650w ( must be platinum if so ) or 750w.
01-25-2014 12:49 AM
01-26-2014 04:18 PM
01-26-2014 04:19 PM
01-26-2014 04:21 PM
danskieness wrote:
btw did you know that bitfenix prodigy is a good contender in the mini itx form factor also?
here's some helpful links
http://rog.asus.com/forum/showthread.php?33649-PC-Build-Guides-for-Haswell-4th-Gen-Core-i5-i7&countr...
^you could just follow the same itx build and replace the board with mvii
01-25-2014 01:42 AM
01-26-2014 04:29 PM
Nate152 wrote:
Hi mirejtr Welcome to the ROG community. I would go with the gene and out of those two mico atx cases I would choose the parvum. Both boards are about the same price and the gene supports 32 GB of RAM where the Impact only supports 16GB. Depending on the games you play you.re going to want to get a decent GPU like a GTX 670 or better and that will require a larger PSU in the 750 watt range. Will you be going SLI? That will require even a larger psu 1000 - 1200 watt range. SLI will give you almost double frames per second when gaming. And I can confirm SLI is nice. Not sure of your RAM speed but I would go with G.Skill Trident X 2400MHz. The Samsung 840 EVO's are one of the best SSD's out there right now. You're going to need a deecent cpu cooler if you decide to do any overclocking. I would go with the corsair H80i but you may have to do a little case modding to get the fan/radiator attached. As for your monitor, I would look at the quality brands of the size you want and read some reviews. I'm not sure how far you will be able to overclock your cpu with the H80i as the haswell cpu's do run hot but, it will be better than a heatsink and fan. One more thing, thie i5-4670k is perfect for you.
