need advise for first build...
bboy
hi guys... noob here.. i want to build a system for gaming.. this is my first build.
Mobo: AMD 990FXCROSSHAIR V FORMULA
Processor: AMD FX-Series AMD FX-8150 TDP 125W 3.6GHz×8
Memory: CORSAIR DDR3 1600MHz 16GB 4x240 DIMM
Case: NZXT phantom white
HDD: Western Digital Caviar Black 1TB 7200rpm 3.5inch SATA 6.0Gbps 64MB
VGA: ASUS RADEON HD7870 HD7870-DC2-2GD5
PSU:Silver Stone ATX12V2.3/EPS 1000W
CPU cooling: Corsair h100
Is this a good set up...? will these part go w/out a hitch? TY guys..
11 REPLIES 11
HiVizMan wrote:
May I enquire as to how you came to be using AMD?
first its cheaper. and also because i,m planning to use it on VMware.. hoping that the cores would greatly help me... im really a
noob about this stuff. but theres always a first time. 😛
HiVizMan
Level 40
I just inquired because there is a rather large difference in performance between AMD and Intel currently.
Both will do what you want. In the UK the FX cpu you have selected and the i5-3570K are the same price. A suitable Intel motherboard cost about the same as the CPU here. For example the ROG Maximus V Gene is in fact cheaper than the CPU to purchase. I do not know if that is the same in your country or how prices are for AMD v Intel.
