I just bought the Asus Ryjuin 240. Here is my need for advice. I have the asus strix z370-e gaming MB and it has only has 2 fan headers and as my case has 3 is it okay to use the cpu-fan header as i have the Ryjuin plugged into the AIO_PUMP header. will this cause a conflict with the AIO and software controling it?
Asus strix z370-E
INTEL I7 8700k
Corsair Vengeance RGB 32GB 4 x 8GB DDR4
ASUS ROG GeForce RTX 2080 Ti ROG-STRIX-RTX2080TI-O11G-GAMING 11GB
Corsair H100i v.2
corsair HX 1000 i power supply
Asus PG278Q monitor
