need advice or sugestions
kkn
Level 14
every part is taken from http://www.aquatuning.com page
kind of regreted that i dident add the part numbers ( for quick shop or what you call it )
FrozenQ Liquid Fusion V Series 250mm - Red
EK Water Blocks EK-CoolStream RAD XT 360
Aquacomputer Aquastream XT USB 12V waterpump- Ultra Version
mod/smart LEDready 3mm to 2Pin - red ( geting a few of theese )
EK Water Blocks EK-Supremacy - Nickel
Alphacool Coolmove 2000rpm 3-Fach Bundle 3 vifte
or - Phobya G-Silent 12 1500rpm Red LED 120x120x25mm 3-pack
or - Silverstone 120mm Air Penetrator SST-AP121-RL + Silverstone 120mm Air Penetrator SST-AP121
hose Tygon R3603 12,7/9,5mm clear
13/10mm (10x1,5mm) compression fitting outer thread 1/4
i know i added a few diffrent fans but, i havent made up my mind on em yet so.
this is for an intel setup.
case : NZXT Switch 810 Big Tower
HiVizMan
Level 40
Not really familiar with the pump, but it looks pretty hefty. I am a boring 655 kind of pump owner.
kkn
Level 14
a friend o mine have it, you can set up pump speed and temp and fan speed++ in the soft ware on it.
i have the same controll unit as paslis got on his bench ( the next level tread ).
its either that cpu block or xspc's block. ( both have holes for led's )
havent desided yet.
