need advice on motherboard..
aky108
hi guys i am going for a new build and need advice on motherboard.....
should i go for rampage 4 extreme socket 2011............ or new maximus extreme z87 socket 1150....
haswell is new hence more appealing...does it perform well?
15 REPLIES 15
HiVizMan
Level 40
Even Ivy bridge outperformed the X79 platform. So short answer is yes Haswell does.
Zka17
Level 16
What you would use your new system for?
The the Rampage IV Extreme is for overclocking, for everyday use it's an overkill... also, the LGA2011 CPUs are usually expensive...
kkn
Level 14
get one of the new maximus 6 series motherboard. ( LGA1150 )
gaming and a lill OC-> geene to hero
for hardcore OC -> extreeme
thanks guys for the advice....
after a long time i am going to build a gaming pc....which would last for a good amount of time (5 years),as i dont want to spend again and again on upgrades.....(except graphics cards)..
i think maximus 6 extreme is a good choice.....but is the ultimate?
HiVizMan
Level 40
For gaming you want the Hero or the Formula not the Extreme
The sound is not geared for gamers on the Extreme, that board is for the extreme bencher and LN2 user. 🙂
fbm211
Wait a couple weeks for the maximus VI formula
Maximus VII Apex
Intel i7 10700k @ 5GHZ
Custom Water Cooling
Patriot Viper Steel 4400 17-17-17-36-300-2t
GeForce RTX 2080 Hydro Copper
WD Black NVMe 750 500g
Seasonic Focus GX-850
Lian LI O11D XL
Dell S3220DF Monitor
Vanatoo T 0s speaker system
ROG mouse
Audio Technica ATH-AD 2000x headphones
AE-9 Sound Blaster
HiVizMan
Level 40
Should be out sooner than that I am hoping. Right now the Hero is a very nice option I must say.
Arabicuser
I will wait as well because after 3 rigs, i am looking to have one of those new Haswell and turn one of my current to have Win XP and Linux and/or Hakintosh, i don't want to have multi OS on my new computers, and maybe i will use Win 8 or newer OS coming on that new Haswell rig if i bought.
Asus Rampage IV Extreme
Intel i7-3930K
Gigabyte Nvidia GTX Titan Windforce
Patriot Viper 32GB[4x 8GB] 2133MHz
H100i
Samsung 840 Pro 256GB 2x
Western Digital Black Caviar 2TB 7200rpm
Corsair AX1200
Cooler Master HAF X
thanks guys for the help....
surely all the Rog boards are just fantastic.....
