Hi, Everyone, this is going to be my first post, and its one is serious about in a fun way,
I have been given an insane budget of $100,000 that's not to say I should go that high for building a pc, but this is going to be used mostly for rendering projects.
The rendering projects don't seem like they're going to be heavy as mostly its just rendering scenes and environments but would like to render while editing and working on the 3D projects actively; the other primary use would be gaming with recommended gaming accessories, etc.
The space used would be quite spacious using an UPLIFT V2 Standing Desk 80 x 30 unless another is recommended and with some space on the side i'm not sure how much though, I can try getting more about it, but at least I got the main desk space. User will be playing a lot of flight and space simulator games; one of notice is Star Citizen and elite dangerous were mentioned.
so I ask you the community what kind of build could you imagine with that budget while being for the price and build while having peak performance and quality? would love to hear build ideas, advice, warnings, etc.
(as a not) I really don't want to spend like that much either I think the person thinks PC is just expensive and has the wrong idea for what a workstation cost bud does want something thats still overkill.
Thank you all!
