Need a Suggestions for Graphics Card in my PC Build
veerpratap
Hey Guys,
I’m new here, I am building my own gaming PC. So as you can see I’m a bit confused about my graphics card can you help me to suggest something about this, and I need the best yet affordable graphics card for my Build?
PC Builder Part List: https://pcbuilder.net/rigs/47yrYP/
1. Processor: AMD Ryzen Threadripper 2950X Processor 16 Cores & 32 Processing Threads, with Cooler ($799.00 @ Amazon US)
2. Motherboard: ASUS ROG STRIX X399-E GAMING AMD Ryzen Threadripper TR4 DDR4 M.2 U.2 X399 EATX HEDT Motherboard with onboard 802.11AC WiFi, USB 3.1 Gen2, and AURA Sync RGB Lighting ($726.99 @ Amazon US)
3. CPU Cooler: Corsair H100i RGB PLATINUM AIO Liquid CPU Cooler,240mm,Dual ML120 PRO RGB PWM Fans, ($197.00 @ Amazon US)
4. Case: Lian Li O11 Dynamic XL ROG Certified ATX Full Tower Gaming Computer Case ($235.07 @ Amazon US)
5. Graphics Card: ASUS GeForce RTX 2060 Overclocked 6G GDDR6 Dual-Fan EVO Edition VR Ready HDMI DisplayPort DVI Graphics Card ($806.49 @ Amazon US)
6. RAM: G.SKILL Trident Z RGB Series, 16GB (2 x 8GB) DDR4-4000MHz Desktop Memory with CL17 ($250.39 @ Amazon US)
7. Storage: SAMSUNG EVO 970 Plus 2TB PCIe NVMe M.2-2280 Internal Solid State Drive with V-NAND Technology & 1024MB Cache ($299.99 @ Amazon US)
8. Case Cooler: NZXT AER RGB 2 - HF-28140-B1 - 140mm - Advanced Lighting Customizations - Winglet Tips - Fluid Dynamic Bearing - LED RGB PWM Fan for Hue 2 - Single ($29.99 @ Amazon US)
9. Power Supply: Corsair RM 850 Series, 80+ Gold Certified 850W Fully Modular Power Supply ($134.94 @ Amazon US)
Total: $5,973
Generated by PC Builder on 19th of May, 2021
0 REPLIES 0
