My solution for ROG STRX B550-F WIFI II constant Reboot will not post
Biermeister1
Old thread closed on ROG STRX B550-F WIFI II constant Reboot will not post
board was sent off to service center they found nothing wrong with board
board had same issue upon inspection of board with magnifying glass found solder hairs back side of panel connections Reset pins. used soft nylon brush to remove solder hairs from back of board.
Upon further testing with AMD Graphics card went to AMD site and downloaded the updated software for the processor and chipset Amory Crate is outdated on that software
Put original NVIDIA graphics back in and computer back together and running no problems now
to the Moderator that helped me Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
System is strong and working fine now
Fabian_m1982
im having issues related to drivers aperently. hope your system works now!
