02-03-2014 12:56 PM - last edited on 03-05-2024 11:45 PM by ROGBot
02-04-2014 02:35 PM
Nate152 wrote:
Closed water cooling loop for your cpu is fine. Even if you liquid cooled your graphics cards you wouldn't get any more performance as you cannot adjust the voltage on them without some kind of a bios mod, and even then I'm not sure you would be able to. NVidia has locked the voltage on the kepler cards.
02-05-2014 04:59 AM
02-05-2014 09:19 AM
kkn wrote:
well no one can say for shure.
if you get a good cpu you can push it high.
if you are unlucky and get a poor one you may not be able to go past 4.0ghz.
its a lotto on that since each and every cpu is not 100% the same when it comes to be able to OC.
02-05-2014 09:28 AM
GrZeLa wrote:
So hopefully i will get this good one. By the way you pay a lot of money for cpu and you're not sure at the end of what you will get, GOOD or POOR one for OC. This is sad.
02-06-2014 11:33 AM
02-07-2014 01:29 PM
02-07-2014 08:24 PM
