Mounting a Corsair H80 on a Asus ENGTX560 DC/1GB... possible yes. Know how, No.
Syber
So really I'd like to know how to fit one of them on to a 560. I've seen videos on YouTube and people did say that the temperature dropped from 80C at full load to 60+/- C at full load.
Now I know that i can use zip ties to mount it on, but that just doesnt look neat. So 1 question is: What socket bracket would fit said card so atleast its actually mounted instead of just hanging there.
and question 2: the rad is 120MMx120MM. Where would be the best place to attach it to then keeping in mind i want to get a H100 for the CPU and want to fit this at the top for the Push/Pull config.
No, I do not have the parts for the PC yet. Still have to wait until may, but I'm exploring things.
The case that will be used is a ThermalTake Armor V4 BlackEdition. its not the biggest but certainly will do with a maximus IV Gene-Z. Also I know it may not sound as cool to you as it does to me, but I just can't afford a full 360Loop.
And I am sick and tired of the air coolers making such a racket in my current pc that I just want to through it out of my window at times.
Anyway many thanks in advance!
Gr33tz
Syber
Current Specs:
Asus Crosshair II Formula ( running old school )
AMD Athlon64 le-1600 @ 2.8Ghz
2GB DDR2 800MHz
Sapphire Radeon HD3870 512MB @806Mhz
Live to WIN! - Paul Stanley
The Choice Of Champions - Asus ROG.
6 REPLIES 6
edub404
That's actually a very smart idea and i am too curious
MOBO - Crosshair V Formula
CPU - AMD Phenom II x4 980 BE 4.2 😄 overclock
COOLER - H60 PUSH PULL
RAM - 8GB G.Skill RIPJAWS X
GPU - HD 6870x2
HDD - 1tb
PSU - Rosewill 630 This PSU is GREAT
CASE - Coolermaster Enforcer
OS - Windows 7 Ultimate SP1 64bit
Simple But Gets The Job Done:cool:
HiVizMan
Level 40
I have used CPU coolers on graphic cards in the past to good effect. The trick is finding a suitable mounting system, what I did was use bits from different coolers and simply bolted the unit to the card. Does not matter if it looks like a dogs breakfast as long as it works.
Syber
yeah true, I do want to try to use the mounting bracked thats already on the card, and mod the mount on the cpu cooler to fit the mount on the card. just have to try it when i get all the components 🙂 otherwise I'll use the temporary zip tie solution
Current Specs:
2GB DDR2 800MHz
NemesisChild
Level 12
You'll probably have to buy new heatsinks for the vram modules, use a good TIM btw.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
Syber
Thanks for the advice 🙂
Current Specs:
2GB DDR2 800MHz
frisianbear2002
I think its possible you only need to make a proper mounting system to fit it.:cool:
l Asus Rampage 4 Extreme l intel 3930X@ 4800Mhz (1.45volt) 24/7 l Asus matrix GTX 580 l
16GB Team Xtreem DDR3 PC3-20800 2600MHz (11-11-11-28-1)
l Coolermaster Silentpro 1000w PSU l Revodrive3 ssd l WD Raptor 150Gb (10000rpm) l Corsair H100 wc with 4 Cougar Vortex fans l CM HAF 932 Avanced case l Acer X243H 24'' l Asus RT N66U Dark Knight l Logitech Z2300 speakers
In progress the custom build PC Samurai Warrior ''Miyamoto Musashi'' in Japanese ''宮本 武蔵'' made by Pascal
